LS2 vs LS3
Old Jan 4, 2019 | 06:04 PM
bigsapper's Avatar
Question LS2 vs LS3
Hi!
I recently got into a 2004 C5 Corvette. I'm looking to the (distant) future on a 400+ci build. I've noticed quite a few C5 builds using an LS2 base for the build, typically 402ci. Alternatively, a common large cube package using the LS3 is 441ci.
Considering the are both Gen Iv blocks, is there a reason to prefer the LS2 over the LS3? I would think in either case, you have the same set of problems to solve for replacing an LS1/LS6.
Thanks for reading!
Old Jan 4, 2019 | 06:06 PM
bigsapper's Avatar
Mods, if this thread is more appropriate in the Gen IV section, please move.
Thanks for moving the thread.
Old Jan 7, 2019 | 07:27 AM
99 Black Bird T/A's Avatar
LS2 vs LS3
I've read the LS2 block is better if one plans to do a sleeved set up. It's been said LS2 blocks can sometimes go .030 over for 4.030 bore. I don't know how common those block are to find.
LS2 blocks seem to be less expensive.
New LS2 block under $1,300
New LS3 block over $1,900
​​​The LS3 has the bigger stock bore.
LS2 402/408 stroker vs LS3 416 stroker - the difference ~8 to 14 cubes. Say 10 to 15 hp for NA applications. Is that worth $600? I would say depends on the person and their budget.
Old Jan 7, 2019 | 08:00 AM
bigsapper's Avatar
Thanks. Ideally, I'd like to go 454. Saw a Tony Mamo build just went up for sale. 2 years too soon for me, lol.
Old Jan 7, 2019 | 08:20 AM
Darth_V8r's Avatar
Moderator
Might be cheaper to grab a used ls7 short block. 427 are not too shabby
Old Jan 7, 2019 | 08:18 PM
Definitely agree that a used LS7 short block would be much better bang for the buck vs making a 454 out of an LS2 or LS3.
Old Jan 7, 2019 | 09:35 PM
bigsapper's Avatar
Looking around at some of these builds, I might get to my performance goals with a little smaller ci. Looking to hit 10.9x in 3,500 DA without going over .600 lift. I've seen a couple of 402 LS2 builds that are right there, but too much lift & converter than I want. Figured I'd make it up with cubes.
I have a strong preference to go 454. Looking at the RHS block, too.
Old Jan 7, 2019 | 10:32 PM
Darth_V8r's Avatar
Moderator
Can get a 454 on a LS next block for 6k from shafiroff. I almost did but went 428 instead
Old Jan 15, 2019 | 04:23 AM
cmysix's Avatar
LOOK at my SIG. this is what my lowly LS2 is up to without much work. About to bolt a set of TRICK flows on, wonder what that will do?
Old Jan 15, 2019 | 06:18 AM
bigsapper's Avatar
Nice! Any 1/4 mile times?
