Help Choosing a Cam for my LSX 454
#42
I‘ll look into that after the mechanical MAP filter. Kinsler for example sell these for big cam ITB applications so I assume it works. But good to have a backup and an option without additional hardware.
#43
Alpha-N is the other tuning method that I’ve seen referenced for ITB’s and setups with poor vacuum signal like dual giant four hole throttle bodies on top of a tunnel ram. Alpha-N mimics pretty closely what mechanical fuel injection does which is just fuel flow vs TPS. There are some more tricks I think with the usual refinements for IAT and ECT and also I think something in there for rate of change of TPS as well.
#44
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
