DRY-SUMP options?
The ARE (Armstrong Race Engineering) setups are really nice.
In my opinion the dailey stuff is top notch. I just went through a ARE 3 stage suction setup in a c5 corvette. The issues with the scavenge lines clearance more than justify the added cost of the dailey pump and pan. You also cannot run the r/s engine mount in the vette so a engine plate is needed. I custom built a r/s mount with a solid left side to make it work.
