Comp Cam BSR rockers
I've tried searching but I couldn't find anything on these rockers. These seem like a good option for someone on a budget like me.
I'm thinking about trying these on ported ls7 heads with a mild cam but I can't find any feedback from anyone running them.
What do you guys think?
https://www.enginelabs.com/engine-tech/cam-valvetrain/sema-2018-comp-cams-bsr-shaft-rocker-system-for-ls-engines/
There’s an thread over on Corvette Forum. The guy bought the setup, installed it and was initially upset because he had to change pushrods, and the company guys swore the stock pushrods would work, which apparently they won’t. So he took it all back off and went back to his standard setup. It ultimately got figured out and he seems happy, but in true Forvette Forum fashion, lots of guys started hating on Comp because the pushrod length deal. LOL.
The setup has a provision for pressure fed oiling to the new bushings, but it’s up to you to figure that part of it out. It requires a banjo fitting be placed on the end of the tube, and then you run a -3 or -4 line to the fitting, but I’m not sure how you’ll get through the valve cover...I guess with a bulkhead fitting?
Its a new setup for LS engines, but the overall design has been used for decades in Mopar stuff.
ZOMG! I don't know how to use calipers and read a number! This product is junk!
Hey, ya gotta understand Vette owners want EVERYTHING pre-fit, pre-guessed-at, and preferably pre-installed. These ARE "premium" vehicles after all! BTW, never remind them some of their engines are just modified truck engines. LOL
LS1Tech Sponsor
Received 1,129 Likes
Those are a neat setup. OnAllCylinders interviewed on of their engineers at Sema. The article is here. Here's a link to the 3 versions on our site.
Thank you for your community efforts.
