RHS block good or not ?
hi guys iam planing to buy a rhs block, i have heart in 2015 any blocks are cracked in the engine mount area .
has rhs this isue solved ?
iam going high compression N/A 4.130" bore round 700whp.
thanks
thanks
For NA and at that power level you should be fine. See if you can get the mtg date to confirm No issues with RHS. Perhaps a sleeved block or Dart aluminum block would be a better option if you're unable to get info on that particular block
Location: Coast of San Mateo County Between Pacifica & HMB
Or the GM LSX Iron. If I had to have Aluminum I would use the CPR Blocks, larger
Bore Capable as well. I would not use the rhs Blocks too much money &
too many problems in their history.
my .02, good luck
my .02, good luck
I would stay away from the CPR/LSr block. I had a real bad experience with the mfg that hasn't been resolved to date. If aluminum aftermarket is a requirement I'd stick with Dart
