Who's using Johnson ST lifters?
https://ls1tech.com/forums/generatio...l#post20075676
if I use the generic 1.70 ratio, the lengths change by .0035 to .028 longer, and if I use the 1.72 ratio advertised by Texas Speed, the lengths change by .0036 to .0288. Looks like I need to get hold of Al again. If they've already started the order, hopefully the differences aren't critical. Using the 1.72 ratio on the chart, the the distribution of the lengths are within 30 thousandths.
The new lengths with preload included were all within .020" except two outliers.
got the rods in, put them where they were supposed to be, redid the procedure for a 3rd time to double check because the rods were all ordered a little heavier by my guy due to the rod ends he uses, and sure enough a few were now not where i wanted them to be. swapped a few rods but keep in mind, i had to do double the work since i had to loosen intake rocker to do the exh on that cylinder, even if the intake was fine. couldn't figure it out why by looking at my measurements on the sheet. so guess what, we do it a 4th time, being super picky and careful, writing down the ratchet clock position on each rocker then using my sheet to determine where i could move things to make it work. that took like 2 hours right there because even tho on paper swapping 2 should make sense, when i checked them it didn't. but not trying to brag, but if my numbers are correct and rocker bolt turn didn't let me down, im at cold preload of between .038 and .047 on all mine, give or take id say .003 cause im not perfect. so after expansion of somewhere between .008 and .012 depending on where you read im right where i wan to be. i did have 1 come in at around .050 for some reason and another at .035 so one is heavier than they recommend but i think it will be fine, and the other is at the minimum or a hair under. just redo it and if you have to order rods, you might be able to use some in other places that you already have and may only need to order 7-10 rods. all the best. you made it this far, try to get it done right
I was not happy with the wipe on my setup. I spent close to $100 on various washers to shim those stupid things and still could not achieve a proper thickness with out the need to stack 2 various washers to get a good pattern. Nothing I ordered was as advertised on the thickness. Also the thickness would vary a bit between washers. Once I achieved a good wipe, I ended up making a set of custom washers for my application. All 1 piece and consistent thickness. I kind of wish the stands were longer and needed to be cut down at the base or that you could order some longer stands once you figure out the length needed.
Once that was done then I could get an accurate Pushrod length measurements....
My point in the other thread was that if you center the valve tip at mid lift you will always get a wider pattern and it will be biased to the intake side of the valve tip.
My point on that post was simply - doing the mid lift method will not get that nice tight wipe pattern.
Use the Comp PR Checker and a digital gauge and report that total length to Manton. It comes out fine.
But to get zero lash... I don't bolt down the rocker being checked as it introduces preload in the bolt stretch. I simply turn the bolt over and push the trunnion into the pedestal and adjust the PR Checker until there is no more up and down chatter in the rocker.
Important Note: make sure you're on the base circle of the cam of whatever valve is being checked. Also, bolt down (fully) at least 2 other different rockers to set the pedestal on the head without movement. So it's a little bit of a tango to move back and forth. But that way you know the pedestal is set and the PR being checked has no hidden preload applied. It also allows for quick adjustment of the PR length checker since you just pull the rocker off and adjust (if you're not close).
Further, it helps to tape the PR Checker so it sticks at the length you measure.
But that's a pretty simple way to get length @ zero lash. Then add the preload of .035" to it and done. Move to the next one.
Even with the motor in the car, I can check all 16 in about 40 mins doing 2-3 measurements.
Hope that helps.
Hope that helps.
I fought this on the first one and said there has to be a better way. I used some blue masking tape and boom no more movement. Easy to remove too.
The bottom end is now where I think I want it. Heads are still unported 66cc L92's, so plenty of room to grow into a more desirable N/A combination.
