King main bearings setting up loose?
1: 2.5588" ; 0.0031“
2: 2.5587" ; 0.0030"
3: 2.5586" ; 0.0035"
4: 2.5586" ; 0.0034"
5: 2.5589" ; 0.0034"
All measurements were done with a micrometer and a bore gauge (4 times with the same results). I might plastigage them just for grins as a sanity check. I wasn't expecting std size bearings to be so loose. Do I just bite the bullet and spend the $100+ on a different bearing brand either in std or 0.001 under? My fear is that I'll drop the cash and they'll still be loose, unless this is a common phenomenon to King si series. I've built several engines, latest being a 400+ HP Ford 2.3T and a 700 HP Audi 2.7T so it's not my first rodeo, but never used King bearings before.
Any thoughts or advice?
EDIT: as soon as I move the bore gauge about 10-15 degrees off vertical all bores fall into 2.7510". I'd expect that at 45+ degrees... Weird.
My block was line honed.
I was looking to get .0025 and had bought +.001” bearings but ended up with std bearings and got what I wanted. Crank btw was a new Molnar.
Oil pressure is excellent with 10W-30 despite the looser clearances.
Ron
Mine is alum L33 turbo, and when I found a bad thrust, I also noted some slight bearing scuff. Clearance was .0019 at that time.
hence the desire for a bit more bearing clearance. Those bearings were Clevite H series.
Ron
King are just as good as clevite. We sell both but use the king in all our rebuild kits and have sold hundreds and ive installed at least 20 sets with 0 issue.
@ WS6: I originally had King MB5293SI, which measured too loose for my taste. Not a huge loss since they were $25 or so. I replaced them with 0.001 undersize clevite part# MS2199H1 which were $140 through summit (and most suppliers, including your store @ $149.95)
I understand that they may be two different types of bearings, hence the price difference. I have a couple of friends that used kings without issues, that's why I was surprised. No matter, it's solved now, I just finished putting the shortblock together last night.
Whats funny is the h1 is 149 and the h is 139. We have alot of odd price glitches like that. Ill get them fixed though.
I wish I could remember what series I used when I built my 2.3t. I *think* those were p-series but that engine sees 7500 rpm and 30 psi boost routinely.
Since the same amount is being pumped theoretically it should not make more windage or mist. But the change in area will cause the oil pressure to drop. You can picture that in your mind if you are awake at 1:22 answering tech emails hopped up on mountain dew baja blast.
