ls3 new stroker issue
ordered all the parts and gaskets they said i will need to button it up.
btw not my first ls been building em for 15 years.
but first stroker
went to hookup converter and noticed motor only went 180 side to side
never a full rotation
took it out tore it down
im down to crank pistons rods mains cam and lifters. no heads or oil pump no timing chain either.
motor still locks at 180 either way.
never spun under a starter only by hand.
please help. i about to rip apart the pistons and rods. im at a loss.
-Thanks-
Or that something fell in there and only locks in that range.
will do more tear down tomorrow and post results.
thanks.
I think your onto something.
to verify this i went to the garage took the cam out and it rotates freely.
it wasnt the cam retainer or those bolts.
think since its is a 598 lift cam it was off, as in wrong stroke.
how do i set that correctly. to make sure im on the correct stroke and then align the dots.
thanks guys....
Some manufacturers notch one piston and mark it to be use only in the back for this purpose.
You seem to have found your problem but another area that can cause a clearance issue is the windage tray.
but first stroker
-Thanks-
it was 2 things one which was mentioned last night.
Been putting it back together and spinning it at each phase.
All good.
1.It was the cam plate bolts one was too long and locked the crank at oint to point as previously described.
2. windage tray needed to be spaced out has some rub on 3,5,7. not enough to lock like the cam plate bolt but enough to mark the tray and spacing it with 2 stainless washers per hole was enough.
Thank you guys for all the input and help.
Hope this helps someone in the future.
All good.
