Main bearing clearance issues
Following this thread. I am building a motor and tried using plastigage. Couldn't get any consistent results. I'm taking mine to my local shop to have them measure everything...
Excellant idea. If you don’t have the means to accurately measure it yourself, please have it done by a pro.
I'm going to wait until it cools down and see if the temperature has something to do with it as it is supposed to be done at room temp.
Plasti squish readings can vary. Was this on a dry surface or lightly oiled surface?
You could put 1and #5 bearing in the block if u have a dial indicator and check run out on your crank.and just because it new means nothing.im dealing new RHS block that supposed been honed to 4.165 guess what.wiseco was right on the money 4.161
New should, but does not mean, correct.
Have all the bearing ring caps on the correct way? I just learned there is a little more to this than I thought.
Also, some people use a seating torque for the main caps at first, break them loose, then torque to value.
Ok changed several things and re did it twice. Got a new degree torque tool and on the first one I used the same plasti gauge brand on the second one I used a different brand. The 2nd one I rotated the crank 180 degrees ish.
Have you installed the crank yet to see if you could turn it by hand and finger?
