AC Delco 12588670
Old May 27, 2019 | 12:09 AM
Joystick's Avatar
Default AC Delco 12588670
Can anyone tell me if this timing chain damper also fit the LS3 (2011 Camaro SS)?
It’s only listed for LS1, LS2 and LS6.
Thanks
Old May 27, 2019 | 10:13 AM
It should fit any LS block with the 2 drilled and tapped holes in the middle of the timing set. Most late blocks do.
Old May 27, 2019 | 11:17 AM
Joystick's Avatar
Ok, thanks
Old May 27, 2019 | 01:44 PM
RB04Av's Avatar
All blocks have the holes, sometimes you just have to move some metal out of the way to use them
Old May 28, 2019 | 11:05 AM
themealonwheels's Avatar
You sure about that? I thought there were two different bolt spacing options for tensioners. I'm not sure, but I don't think your statement is true.
Old May 28, 2019 | 12:03 PM
Joystick's Avatar
We’ll see, I already ordered one, let you know once installed.(If it fits)
Old May 28, 2019 | 03:23 PM
RB04Av's Avatar
AFAIK the holes are the same spacing.
I did note while clearing the excess metal in my block out of the way using my electric hole-finder, that they aren't symmetrical on the block. The whole hole pattern is offset about 1/8" or so to one side. Maybe putting the tensioner in upside down could lead to the impression that there's 2 patterns?
I didn't use the factory one though, mine was from some other vendor. Looked an awful lot like a factory one except a different color. But AFAIK that vendor (sorry... can't remember... as they say, your memory is the 2nd thing you lose as you age, I just can't remember what the 1st one was supposed to be) only offers one part #.
Old May 30, 2019 | 04:28 AM
62vette's Avatar
Most aftermarket companys list 2 dampers 1 for ls1-6 and 1 for ls2 onwards
Old May 30, 2019 | 09:14 AM
Joystick's Avatar
http://www.improvedracing.com/timing...670-p-263.html
According to Improved Racing there are two different, the 12588670 is for Gen IV LS2, LS3, LS7
Old May 30, 2019 | 11:55 AM
Ah, thank you! I knew I wasn't crazy... I remember worrying whether I was getting the right one when I was doing my 2004 LM4 motor. There was someone on eBay selling a limited quantity of the rarer ones with the right spacing if I recall correctly... that was something like 8 years ago for me lol!
Old May 30, 2019 | 12:03 PM
Joystick's Avatar
8 years ago.......... that’s a pretty good memory��
