High torque 6.0 build cam
I have a dmax with a blown h/g. I bought it that way with intentions on fixing it. Really driving it around a little now and then to keep **** working and the battery charged you wouldn't even know it. But it pressurizes the rad.
1. Keep duration mild on both intake and exhaust
2. Keep a fairly advanced icl like 107 to 109
3. Keep lsa narrow
4. Add lift
This is exactly why a cam like the stage 3 high lift from tsp is the best at what youd want to do. Itll still have negarive overlap but a noticeable idle and make some great bottom end and mid range. I have a dyno graph comparo i post all the time showing the difference in lift and duration of 4 cams the higher lift adds power and torque through literally the whole rpm plus adds a couple hundred rpm on the top end.
There are obviously other things to do with the engine, but as far as trying to match that idea up with any ls6 car cam, they are terrible at all of that. Super wide lazy lsa and weak lift.
It just reminded me I need to speak to my engine builder about this.
Do you know if this offsetting will cause any clearance issues with the heads or intake manifold?
It won't affect sealing?
So when you offset the dowels does it change your bore size?
