LS1 383 Stroker or LS3 Swap
Obsolete motors now lol Funny how a old SBC was still used readily into the late 90s the LS1 had a decent 10 year span and then the LS3 sealed the coffin on it. Great little motors but so much more potential in the LS3.
Moderator
Received 1,852 Likes
I'll take all these scrap LS1's off peoples hands since they're not worth anything.
Completely depends on power goals. Anything over cam only power (north of 400whp) and boost starts to make sense over NA given that its easy to spend over $1000 on heads and $1000 for an intake/TB. A stock long block LS1 with a cam and springs (may not want the cam but it is nice) will do 600whp with boost and live if tuned right for a long time. Some go higher, but that's a rule of thumb. It will drive better and have a better torque curve and not require rev'ing as high. As far as type of boost, it depends on goals and fabrication abilities. Don't want to adjust boost or deal with welding, then go Procharger or Magnacharger. Bolt on and go and typically are easier to package as there is no "hot side in the engine bay". Turbo's have more head room for future power growth for little money (turbo's are cheap these days), and hit full boost faster than Prochargers. Pick your turbo size based on how much power you want to make and how high you want to rev. Prochargers and Magnachargers are more set it and forget it for a single PSI level. Max boost is max RPM. Centrifugal blowers are easier to hook up on the street. Magnachargers (roots style) are violent off idle as they make peak boost very early and are killer for heavier cars, but packaging is tougher like in an Fbody. I'm in the middle of building a rear mount turbo setup because I got a good deal and have only built front mount turbo setups before. I'll have <$2500 into my entire turbo setup that'll make 600whp without working too hard, keeps A/C and all accessories in the stock location, and no hot side under the hood to deal with. When I rebuilt my LS6, we opened the ring gap "just in case" and I picked a cam that I felt would work with NA or boost. We'll see how it goes!
For a high mileage LS1 with about 220k miles on it, would you still risk going F.I on a stock motor or would you rebuild it?
Sounds pretty insane. 600RWHP is still no slouch especially for under $2.5k. What Turbo did you go with and did you go for a rear mount kit or just custom fabbed it?
I had an LS1 stroker, a 383 with Dart 225 ported heads, a 243-251 LSL lobed cam with an Edelbrock ProFlo and it ran very well, made 534rwhp with 518 SAE corrected through a T56 and an 8.8 on a SuperFlo 4wheel dyno, I wouldn’t even consider building anything using a Gen3 aluminum block now, they’re kinda 10 or more years ago.
To me building a ~ 425whp to 450 whp LS1/LS6 can still be relevance for a fun cruiser or daily driver...there are a lot 240SX's, S2000's, Valve's, BMW's and 3rd Gen Camaro/ Firebird etc that greatly benefit from any hand me down LS swap.
He asked me if it was a good price. I told him to do that deal before the buyer discovered the internet and changed his mind.
#32
Moderator
#33
64post, that's a very nice result with an 383 LS1 stroker...kudos! Agreed for the serious hp definitely the Gen 4 and new LT platform are where it's at.
#36
LS3 is the way to go here. No need to give it too much though IMO, But, if you opt for the small bore stroker then use a Gen4 5.3 block like LH6, this is a much better foundation with Siamesed cylinders, better bay to bay breathing and thicker bulkheads. Can be safely bored to accept 3.905 piston.
#37
So you need to answer the question, how much power do you want and how do you get there. The bigger numbers are either a LS3 stroker or heads, cam and Blower or turbo 5.7 or 5.3.
#38
