Projekt Lazarus - Numbers Posted!!
Old Feb 17, 2020 | 12:07 PM
  #761
grubinski's Avatar
I guarantee anybody paying attention to this thread won't do it. Good grief!
Old Feb 17, 2020 | 01:31 PM
  #762
sxc Z28's Avatar
So, Chevelle offered to go through the bottom end for me, as I lack a few of the tools needed to do it properly, and I REALLY appreciate it sir!!!!
Got him the motor this weekend. Cool dude for sure. Needles everywhere, which I knew would be the case. Also he's saying the cam will likely have to be cut to come out, which I also pretty much knew. No way the bearings aren't trash at this point, but at least it'll be right. Gotta take care of a few other things on the car while it's torn down this far, but it'll be a much better car when done.
K-member that will allow you to drop the pan?
Very nice of Chevelle!
Old Feb 17, 2020 | 01:38 PM
  #763
Darth_V8r's Avatar
Moderator
Indeed it is!!!!
I have a tubular K already. It still won't drop unless I drop the cradle. The pan hits on one of the steering mounts. Frustrating. for sure.
Old Feb 17, 2020 | 02:15 PM
  #764
98_WS6_M6's Avatar
Indeed it is!!!!
Burkhart's tubular K you can drop the pan while it's mounted. One sitting in my garage if you need it quickly. I could order another
Old Feb 18, 2020 | 08:58 AM
  #765
Darth_V8r's Avatar
Moderator
For those who like looking at train wrecks...
Projekt Lazarus - Numbers Posted!!-photo293.jpgProjekt Lazarus - Numbers Posted!!-photo658.jpgProjekt Lazarus - Numbers Posted!!-photo189.jpg
Good news is the lifter bore is OK...
Old Feb 18, 2020 | 09:06 AM
  #766
bortous's Avatar
Can that cam be repaired?
It looks toasted.
Will you need to take the block back to the machine shop to fix the bore?
Piston looks like it needs replacing.
At least lifter bores are ok.
Old Feb 18, 2020 | 12:24 PM
  #767
A cam like that is not worth repairing. Better to grind a new one. The metallurgy can't be accurately reproduced by welding/regrinding
Old Feb 18, 2020 | 01:27 PM
  #768
grubinski's Avatar
Yes, this is a multi thousand dollar build ... why half *** it by trying to save $400 on a cam?
Old Feb 18, 2020 | 03:19 PM
  #769
01CamaroSSTx's Avatar
When it comes to the 4th Gen and those back cylinders, verifying the pushrod is siting on the can be somewhat difficult and even with the aid of a mirror and flashlight its a PITA!
I'm thinking a borescope could prove useful here.
Old Feb 18, 2020 | 06:35 PM
  #770
rkupon1's Avatar
It looks toasted.
That shyt will buff right out with a rag n some wd40...send it!
Old Feb 18, 2020 | 06:54 PM
  #771
ddnspider's Avatar
That piston is pissed. How bad is the bore?
Old Feb 18, 2020 | 08:25 PM
  #772
Darth_V8r's Avatar
Moderator
In a word, effed. Will have an update soon. For now, I need to drink heavily.
Old Feb 19, 2020 | 06:11 AM
  #773
ddnspider's Avatar
Attachment 708829
Ouch, sorry man. That sucks big time.
Old Feb 19, 2020 | 06:20 AM
  #774
bortous's Avatar
Attachment 708829
Don't drink.
Get some BJ's instead.
Old Feb 19, 2020 | 09:38 AM
  #775
TrendSetter's Avatar
why not both?
Old Feb 19, 2020 | 09:52 AM
  #776
xc_SS/RS's Avatar
Don't drink.
Bojangles? Lol
Old Feb 19, 2020 | 09:56 AM
  #777
bortous's Avatar
Originally Posted by TrendSetter
why not both?
Alcohol is overrated.
BJ's are under rated when it comes to stress relief.
After this engine issue it's best to choose the healthier option.
Old Feb 19, 2020 | 10:02 AM
  #778
Darth_V8r's Avatar
Moderator
Default Projekt Septimus - Now Lazarus
The final nail in the coffin -- Fatigue cracks were found on the crank. After going back and forth with Chevelle and a few others, I do not think all the damage and carnage we are seeing was done by this one lifter spinning. Certainly cylinders 4 and 6 being the worse is from the lifter, but you can tell fresh scratches from old scratches, and that crank was a ticking time-bomb. The spun lifter probably saved my life. After seeing what I have seen from inside this engine, I look back and remember how ticked I was it only made 577, and frankly I'm now amazed it made 577. I'm not going to go into it much more after this, but by all rights, this thing should never have made more than 540. Not all the stuff I'm finding is new. Not by a long shot. So, I'm going to politely thank everyone in advance for not posting up a bunch of questions about the old engine. I'm really ticked off about the whole thing. There's some stuff going on that I'm keeping private. I really do not want to focus on what's under the bridge at this point, and instead would rather just be excited about building a new motor.
I really owe Tony a huge public apology. It was going to be a very scientific project. Heads/cam/intake package swapped out for his package, but a bigger cam, and let's see the difference at the dyno and the track. That plan has completely blown up, and it's not his fault at all. We lose the baseline comparison at this point, no matter what happens, since it's going to be a different bottom end.
So, moving on, I've decided we are going to bring this one back from the dead, like Lazarus! Here's the plan:
1. I have to sleeve the motor. The scratches are too deep to simply hone, ring, and reassemble, and would need to go to 4.150 just to clean up the bores. Given that I have to sleeve, I'm going to go to 4.185 bore for a 440. It costs me nothing to go to max bore above or beyond the cost to put it back to 428. Instead of a pontiac displacement, it's a dodge I guess
2. The old crank was a LS7 factory crank with the nose cut off. I might try to find the same thing so the weights are comparable. It depends on what I can find, etc. I will be able to preserve the titanium connecting rods from the original build - only thing not damaged.
3. Weld repair the head where it got cracked, get back to Tony for massaging, and be ready to rock and roll.
4. Replacement cam and lifter pair from Cam Motion. Cam spec will be the same.
5. Do the top end assembly OUTSIDE the car, lol. it's far easier to install the engine into the car without the heads, but I am not keen on trying to set valve lash sideways AGAIN. With 360-degree access on the stand, I can set it up in far less time and less risk.
I don't think the extra 12 CI will actually make much difference on the power. The heads, cam, intake, and exhaust will still flow what they will flow. What I think will happen is the HP number will match what the 428 would have done, but at a lower RPM. Spit-balling here, but maybe it peaks at 6500 vs 6800, but HP number is the same. But I also think the extra displacement will help tame what is a very rowdy cam (idling at 85-KPa! (but some of that could have been overcoming a dead hole)), bring in the torque a little bit sooner, make about 15-20 lbs more peak torque, and still rev nicely by preserving the 4" stroke. I did toss around the idea of going bigger - to 454/5 or even 468 - but really, I set this thing up for RPM and for this reason would really rather keep the 4" stroke so I can rev it hard.
Block is en route - or will be shortly. Will continue to keep the thread going.
Old Feb 19, 2020 | 10:19 AM
  #779
lazerlemonta's Avatar
Anxiously awaiting the abandonment of this thread and the start of another technical build. Project "didntwannadoit"
Old Feb 19, 2020 | 10:20 AM
  #780
bortous's Avatar
Oh Darth sorry to hear what has happened man.
Move forward and don't look back. Like what I am doing,
Be excited because your new engine will be better than your old one!
I'm sure Tony will help you out with things too. He is a good guy..
Getting a resleeve will definitely make it good again.
Would it be cheaper to just get a new block like I did?
Also Darth, with the cam specs you can always slightly adjust the specs to suit the larger displacement so you have the same RPM range as before.
You might only need a 1-2 degree later IVC maybe.
Do you think it might be worth getting a new crank so it's stronger?
I think keeping the 4 inch stroke is a good idea.
I like the no ******* around approach.
Block is already sent off to be done.
Good stuff.
