Projekt Lazarus - Numbers Posted!!
Old Aug 11, 2020 | 11:18 PM
  #1161
BigDaddy97's Avatar
Best of luck brother.
Old Aug 11, 2020 | 11:41 PM
  #1162
FinalCam's Avatar
Congrats man!
Old Aug 12, 2020 | 04:29 AM
  #1163
Mickyinks's Avatar
I'm with you Darth, Ill be starting up in the morning, just have to connect the battery.
one thing I did differently was bleed the clutch from the master cylinder. Worked great. No getting under the car, no pumping the pedal
Old Aug 12, 2020 | 09:03 AM
  #1164
Darth_V8r's Avatar
Moderator
Thanks guys!
Mickey, if you get the remote speed bleeder, here's a trick... Crack the bleeder, and stuff the end unto your clutch fluid reservoir. Put a mirror so you can watch the reservoir while you pump the **** out of it until no more bubbles. Then, close the bleeder and a few test pumps for pedal check. if it needs more, crack the bleeder again, stuff the end int he reservoir and pump some more. I've had my best results via that method and can do unassisted.
Old Aug 12, 2020 | 10:06 AM
  #1165
I'm with the crowd here.... best of luck to ya Darth! May she fire up clean and stay that way!
Old Aug 13, 2020 | 05:25 AM
  #1166
Darth_V8r's Avatar
Moderator
Very glad I did a once over with a fresh mind. Primed fuel pump and found a fuel leak. Fixed that. Found a coolant leak and fixed. Second round of leak tests went well.
First start went pretty good overall. Pretty happy. Had oil pressure as soon as I bumped the starter. 65 psi once the motor caught. Considering all the changes it started pretty easily.
It has a dead hole. Positive it's a spark wire. I had to stay in the gas to keep it running so I was not able to grab a good video.
Warmed it up, shut it down. No apparent leaks. Lots of smoke from all the handling and oil residues as per usual.
I know the tone of the post is kinda ho-hum. Just gotta chase down the dead cylinder and then I will be more excited. But the major hurdles cleared - no bad noises and great oil pressures!!
Old Aug 13, 2020 | 06:10 AM
  #1167
bortous's Avatar
Good to hear everything going well so far.
It could be a dead coil causing the cylinder issue.
I'm happy also that I am not reading about any pushrod issues etc. (I know I won't let that one go so easy)
I look forward to more updates.
I'm getting pumped for mine also.
Old Aug 13, 2020 | 06:29 AM
  #1168
Darth_V8r's Avatar
Moderator
Pretty sure it's a wire. I had to cobble together eight wires from two sets of used wires done with cracked insulators and boots.
My coils are damn near bulletproof
Old Aug 13, 2020 | 07:08 AM
  #1169
AINT SKEERED's Avatar
fire cores on it?
Old Aug 13, 2020 | 07:19 AM
  #1170
Darth_V8r's Avatar
Moderator
Mixed msd make your own and firecore
Old Aug 13, 2020 | 07:24 AM
  #1171
Darth_V8r's Avatar
Moderator
So 1,2,7 were dead. Lol.
Old Aug 13, 2020 | 07:57 AM
  #1172
bortous's Avatar
Wires or coils?
Old Aug 13, 2020 | 08:25 AM
  #1173
98_WS6_M6's Avatar
There's almost no way it's the coils. Those coils are bulletproof (Lance ftw) and he was having issues with the wires before. As soon as the firecores get there I'm sure it'll fix it. Nice work Darth! Can't wait to hear a good startup vid
Old Aug 13, 2020 | 09:18 AM
  #1174
Darth_V8r's Avatar
Moderator
Wires
Not going to do all eight. One dead and one live hole match compression so I know it is not mechanical. I got fuel. Just weight on gnu wires
Old Aug 13, 2020 | 11:04 AM
  #1175
ddnspider's Avatar
Wires
Do those IGN1's require anything special for wires other than length? Impedance, shielding, etc.
Old Aug 13, 2020 | 11:07 AM
  #1176
Darth_V8r's Avatar
Moderator
It requires a different coil end on the wire. not compatible with stock wires, or i'd run them right now. Only ones I know that will work are MSD and Firecore.
Old Aug 13, 2020 | 11:09 AM
  #1177
bortous's Avatar
When will you have them?
Old Aug 13, 2020 | 11:22 AM
  #1178
spanks13's Avatar
The IGN1A use the usual wire boot/connector for a distributor.
Old Aug 13, 2020 | 11:26 AM
  #1179
Darth_V8r's Avatar
Moderator
Unsure when they will arrive. Soon won't be soon enough lol.
Well, ****, so I just need to find a old school wire set with all 8 wires 10" long...
Old Aug 13, 2020 | 12:08 PM
  #1180
spanks13's Avatar
Yeah you should be able to go to vatozone and get some cheapies to get it started.
