LSX 454 freshen up
Old 08-24-2024 | 07:09 PM
  #861
Mickyinks's Avatar
I took the plug out on front drivers side oil galley and can see that the 5/8 plug is installed.
the machine shop must have installed a new plug and given me the old plug
im satisfied allplugs are done
on a side note, don’t try prime oil pump with out an oil filter lol
The following 4 users liked this post by Mickyinks:
C5_Pete (08-25-2024), Che70velle (08-24-2024), DualQuadDave (08-24-2024), jayyyw (08-29-2024)
Old 09-22-2024 | 05:53 AM
  #862
Mickyinks's Avatar
Got the engine and transmission in , turn the key and the oil pressure gauge and water temp gauges not working. Traced it back to water temp sensor wiring had a break. Just waiting on new water temp sensor which should arrive tomorrow. The old one was reading -40c so it’s throwing a few tps codes. Hopefully can start it up once new sensor arrives
With having my heads ported to Mamo”s biggest port should I throw a couple of percent more fuel at it or start it and see where its at?
Old 09-22-2024 | 01:03 PM
  #863
cino's Avatar
If the camshaft stays the same, I’d start with your existing tune. In closed loop PCM will be more than capable to compensate, maybe bump up the tune in power enrichment to stay safe under heavy load in open loop. Just ported heads won’t change VE/MAF too drastically. You will see the biggest change on top end. Another reason would be to actually find how OFF is the current calibration to see gains from updated heads.
Old Yesterday | 07:11 AM
  #864
Mickyinks's Avatar
I’ve been chasing electrical issues last few weeks , on top of having to pull engine out again due to a dodgy concentric slave. Finally drove it today, got it up to temp, oil pressure 25psi idle 55psi at 5000rpm, old tune is surprisingly close. Drove it 15mins and just as I pulled into garage one of the electrical issues with o2 sensor came back, started to add 50% more fuel. Back to trouble shooting
The following users liked this post:
Che70velle (Yesterday)
Quick Reply: LSX 454 freshen up
