what is max ls7 head milling amount?
they are already milled 0.030”.
how much more can i go and what is the limiting factor? it’s NA and heads are max ported. titanium valves and chambers are finished.
will be using Fast or MSD intake. if that helps the alignment issues. using Jesel valvetrain. thanks!!
I'll go out and look at how bad it lines up already at 0.030 mill amount and then see how much worse its going to get by using no gasket and try to bolt it up. That's a head gasket thickness worth of stock removal.. if its going to line up horrible I'll find out! seem reasonable?
My 4.130" bore LS7 build is using flat top Mahle pistons with 2.5 cc valve reliefs. With the Mahle pistons, 70cc heads is right at 11.8:1 at .040" quench.
My heads are at 68cc right now. I want to take another 8cc off. My heads have been cut .010-020 already. 8cc would be another ~.050".
I'd like to be at ~13.25:1 with flat tops. I wish Mahle made a powerpak piston with a small dome..5-6cc is all I wanted. I got a screamin deal on the shelf 4.130 pistons on sale + $100 rebate via ebay sale. Can't complain.
LS7 w Diamond Pistons
So, A - with these flat ops and cutouts I'm toast on compression and B. I'm already maxed out on the 0.030" mill if I use a thin gasket.
need to find out the piston height and cc.
It was such a major pain before when stuff didn't line up, especially the rocker stands and intake manifold. but those were 0.5" raised port heads.. so I'm not sure what this angle mill will do to everything, but it seems the only way to go to get the CR in the 12.5:1 or more range.
