Help to I.D. head porting
https://ls1tech.com/forums/parts-cla...243-heads.html
https://ls1tech.com/forums/parts-cla...6cc-heads.html
The numbers on the casting pad are done the same way and the combustion chamber work looks the same to me. I think you guys have this figured out.
I recall them being hard to get a hold of. But seems like the do good work. They were also a sponsor also way back in the day.
Richard is a super nice guy who will talk and discuss your needs. I did and came away impressed.
Their phone is (818) 705-5454. Ask for Richard, he knows his stuff.
I think you'll be glad you did.
I have had at least 4 sets of LS heads done and some other stuff that he has finished for me over the last 15 years.
I am concerned with both the compression from the smaller chamber and the possible ptv clearance issues for my build but that should be a whole new thread.
Thanks to all for your help!
You should be fine on either compression. If you're really worried about it skip the expensive cometics and run stock gaskets. The compression will still be awesome at 11.5 static
I have the .041 gaskets already so I think I might as well run them. The difference in compression isn't really that much and with a better quench I'm guessing detonation won't be any more likely than with stock thickness gaskets.
I have a BTR Stg 2 - 227/234 113+2 that I'm planning to run.
I believe 1 cc is .007 thousandths if I remember correctly
so you're closer to .030 off.
