Miata LS3 Build Thread
Car sitting stationary on the dyno is just not the same. You always have to adj the AFR. Unless you have the air intake in the drivers compartment.
I contemplating getting a valve job and milling the stock heads slightly with a gasket and settling for a 465-480 wheel Mavn build with a 224/230 114+3 cam Darth recommended for me; which I like for throttle response or going for the 500 wheel with something like the TSP 255 heads or TEA 255 TFS heads both of which should leave my throttle response in check. I wish I knew for a fact those heads would get me the 20-30 wheel I need which I don't because I've heard it both ways.
I have 295 width Michelin PS4's on my 2013 narrow body Vette. No, not as good as an R compound competition tire, but one of the better street tires out there. Depending on temp and pavement type, they don't have a chance in first gear rolling into it at just about any RPM. They will get loose in second a lot of times too. You also don't get the "lazy 'till 3500 rpm" business that you get with most bigger cams. It pulls a little harder past that, but not as noticeable because it's pulling really good below that.
I can see, dealing with a bigger cam, where a smaller/higher velocity intake port would have low end advantages. I just don't think that applies when you're comparing them with a smaller cam. An LS3 comes with a good set of heads and intake manifold. Buying a high dollar set of heads along with a high dollar intake manifold would be a deal killer for me.
550+ RWHP with MMS Ported OE Intake & TB, Schmedium Cam ~229/243, MMS LS3 Heads (AFR Castings), and
~28 lb MMS RPS BC2 Dual Clutch/Flywheel Assembly.
As someone who spent A Lot of $$$ on a custom LS3 Headed Engine, I can tell you to have a legitimate 500+RWHP
stock stroke LS3 WITH Fantastic throttle response and Great Drive Ability every where will take some Excellent Heads and the right size cam.
My suggestion, for what it is worth, AFR LS3 Heads out of the box with a lighter hollow intake valve, and
The Cam Motion LS3 Titan 3 227/237 113 and Milling with .041 Gaskets to achieve ~ 11.3-11.7:1 comp. tight quench ~.035-.040
depending on 91 VS 93 Octane availability, I would expect ~520 RWHP with a good tune and fantastic throttle response,
along with exceptional low speed/RPM driving manners.
It costs more to "Have Your Cake & Eat it too."
Just my .02
Just my .02
Highway mileage went from 29.8 mpg to 31.2 mpg on my standard "trip to Spokane" measurement loop.
The car has been running a bit over a year on the new engine, a bit over 200 hours, so probably 9000 miles (no speedo or odo in the car, just a tach with an hour meter, because racecar). It's well mannered, smooth, gets great mileage, and is scary fast. I drove down the Oregon coast on US101 to see my Dad in early September, a 2000 mile round trip.
This build met my goal of a usable, stupid fast car. Thanks again to Tony Mamo for his parts and input.
The track day went very well. This was my first time on track in one of my own cars in 18 years. This car has 3x the power to weight ratio of the SC MR2 that I tracked previously, so it was a very interesting day. It took 2 hours to get to the track, I left the house at 4:30AM in order to be there before 6:30AM. The first meeting I had to be at was at 8AM. I like to get places early, but I'll probably leave later next time.
I ran 4 of the 6 sessions available. The track layout used included a chicane in the middle of the main straight, which kept top speeds down a bit. My instructor signed me off to run solo after my 4th session with him, but then I found I had a broken muffler hanger. I did a quick fix with zip ties, but I didn't want to take a zip tied exhaust on the track, so I called the day a win. The goal was to go fast enough to shake down the car, and fast enough that I could start trying to get used to it, all while being able to drive it home at the end of the day. I did all that, so I was happy with how things went. Some sections I went pretty fast (probably got ~130 mph on the shorter than usual straight they were using today), and others I left a *lot* on the table (a section where my car might reasonably be at or a little above 120, but if you mess it up you don't get to drive the car home). I'll start pushing those sections after a few more track days. Unfortunately, I have no video or data of the day. There seemed to be enough things to juggle getting in the car and ready to go on time for each session without adding that. It's more complicated with the instructor involved. My guy was 74, so was maybe not as agile as some in getting belted up, getting the inter-helmet comms going, etc. When it's just me, and I have a system in place, it'll go better.
Overall, the car is very sweet to drive. It's not trying to bite me, very predictable. The brakes worked great, no fade all day and tons of deceleration available. I was a bit worried about this, because there's video on YouTube of a V8 Miata fading it's brakes within 2 laps at a track day. Apparently, my ducting, heat shielding, and expen$ive pads worked. I could certainly have been more aggressive with my braking in a few corners, it will take a bit to get used to really pushing them. They are extremely capable.
I had planned to use mostly gears 3/4 on the track, because on the street, 2nd is usually very hard / impossible to keep out of wheelspin. As it turns out, once the track tires got hot, the car hooked in 2nd just fine (having the extra ballast of the instructor in the car probably helped, too). In 2nd gear, the car accelerates at about 20 mph / second, so 40-80 mph in 2 seconds coming out of slow corners. Tons of fun, thank you Tony Mamo!
In general, I really enjoyed the tires. It's been a **long** time since I've been on hot track rubber, and I'd forgotten how capable it makes the car.I hit the rev limiter (7000 rpm) several times in 3rd gear when the tach was only indicating a bit over 6500. I don't think the tach is inaccurate, I think that when the car is accelerating hard, the tach needle just can't keep up ... I'd noticed this on the street, too. I'll probably have to shift at 6200 indicated from 2->3, and maybe 6500 from 3->4. I won't need 5th on this track layout, because 4th is good to 145. If I ever run here without the chicane in place, I'll need 5th gear. The car pulls hard all the way into the limiter, no feeling of reduced acceleration above 6000 rpm.
Fluids were all good all day. Maximum oil temp that I saw was ~250 degrees, so the cooler seems to be working. Oil pressure can be a problem in LS motors in sustained left hand sweepers at over 1.2G ... one reason this car only has 205 section tires on it, and no real aero ... it keeps the cornering forces a bit lower. I peeked at the pressure gauge in the middle of turn 6 (a long left sweeper) and it was fine, 50-60 psi. I didn't use as much gas as I expected to, maybe 8 gallons on track in 4 sessions, at the most. I added octane booster to the gas in order to give my engine a bit more margin against knock since it'd be hot and under sustained high load. I don't need it on the street, because I'm an old man.
I only scared myself a bit once, braking into turn 6. I'd come out of 5 better than I had previously, so I had a bit more speed coming into the braking zone. The back end of the car was moving around like crazy under the brakes, and acting like it wanted to let go to the right. I used **all** of the track gathering that up, but didn't go off. In retrospect, I suspect I had a little steering lock on when I applied the brakes ... not a good idea if you're braking really hard. I will pay attention to this next time I'm there.
Most tachs have a dampening system built into it so its needle moves smoothly but a really good build can accelerate faster than the tach can now keep up due to that dampening system
I experienced this with my first really good naturally aspirated Big Block build in the 90's (850 at the flywheel).....couldn't understand why I was banging into a 7200 RPM chip at 6900.....LOL
And this was a "Sun Super Tach II" aftermarket tach (Im dating myself now!!).
Ended up putting in a shift light which went off exactly when it was supposed to.
Honestly to all you guys reading this that dont own one, once your making good power you should be paying more attention to the road than the tach and the shiftlight allows you to do just that.
Mike.....get one so you can pay attention to the curves and braking markers.....you shouldn't be watching the tach! Set it a little early if you want a heads up your close to redline.....its infinitely adjustable.
Enjoy the car.....sounds like you had a blast
Regards,
Tony
www.mamomotorsports.com
Tony@MamoMotorsports.com
Anything worth doing is worth doing well. Build it right the first time....its alot cheaper than building it twice!!
The weather was much better than it's been in the Seattle area so far this year. I got a bit of a sunburn, because I had no base tan at all, even though I drive this top down 99% of the time here at home.
No stereo in this car (or A/C) ... I didn't miss either. The steering wheel and the gas pedal provide the entertainment.
