Leaking valve
Old Nov 23, 2019 | 10:36 AM
Dr1rrrr's Avatar
Default Leaking valve
I've been doing a dod delete on my ls and I got my cylinder heads redone at a shop while it was apart. The valve springs I chose where not right for the cam. So I ordered new ones but I had already installed the heads so I am having to install them with the compressed air method. When I got to the number 6 cylinder the intake valve leaked really bad but I don't understand why because it's a brand new valve job from a reputable shop so what could be going on here?
Old Nov 23, 2019 | 11:13 AM
Smokey B's Avatar
Could be leaking around the stem or valve needs lapping. Nothing major. Take it off and have it tested.... the valve seal needs replacing. More than likely a simple fix.
**** happens, a seals got pinched hopefully.
Old Nov 23, 2019 | 11:51 AM
Dr1rrrr's Avatar
Are you saying take the head off cause and air isn't coming out of the stem is coming from the intake throttle body
Old Nov 23, 2019 | 12:03 PM
jlangley's Avatar
I would contact the shop that did the heads and see what they have to say.
You could try opening the valve a few times and see if it seals.
From your description I don't see the valve stem seal being the issue.
Old Nov 23, 2019 | 12:05 PM
Dr1rrrr's Avatar
Yeah I will definitely be contact them they don't open till Monday was just hoping someone could tell me if this has happened to them or something
Old Nov 23, 2019 | 12:07 PM
jlangley's Avatar
You do have the cam lobe on the base circle and rocker arm off of course?
Old Nov 23, 2019 | 12:14 PM
Dr1rrrr's Avatar
Yes rockers are off
Old Nov 23, 2019 | 02:41 PM
dreadpirateroberts's Avatar
i would do this.
if they reused your stock valves, you may need one replaced. sometimes you find one that looks like it seats but is actually slightly bent. they should have checked that if they were rebuilt, though.
could also just have crud on the seating surface and needs to be cycled a few times with the spring pressure pulling the valve against the seat to really seal it, so having the rockers on and rotating the engine over a few times would help.
Old Nov 23, 2019 | 02:56 PM
Dr1rrrr's Avatar
Ok I'll try that
Old Nov 23, 2019 | 06:32 PM
L78steve's Avatar
With the rockers off on the leaky cylinder, put compressed air on that cylinder via the spark plug hole, then tap the valve stem with a plastic mallet.
If the leak clears up great. If not then give the shop that did the work on your heads a call.
Old Nov 23, 2019 | 10:59 PM
Agreed. If the spring is still on the valve, whap the top of the valve with a plastic or rubber hammer a few times, to help the valve seat. Make sure piston is down the hole of that cylinder some or you could potentially bend the valve from interference with the piston top. Very common procedure actually. I do all of my valves this way, head on a fixture, before I install the heads on the engine, just for an extra “because”. Had an engine builder that did all of my dry sump circle track engines in the early 2000’s, that would not lap a valve to save his life. He used the “tap” method which basically is what I’m suggesting you do here, but different...
Old Nov 24, 2019 | 11:59 PM
that actually makes a lot of sense. I will have to remember that trick.
Old Nov 25, 2019 | 05:56 PM
Dr1rrrr's Avatar
I tried the tap method and it seems to have worked thanks for the help guys!
Old Dec 4, 2019 | 12:44 PM
00pooterSS's Avatar
Tap tap taparoo
