How "EASY" is 800hp N/A LS build?
Old Jan 4, 2020 | 10:51 PM
  #261
Originally Posted by Smokey B
No Chevelle.....when the Dumbestest guy Shows the truth....i luv for pride & money to be ate on...from just asking the correct person.
It wasn't funny when i got Trolled...now what? Never tripping... I got Truth and Facts .....no need 4 the Hear say....no respect.
Respect? Show some respect Smoke yourself. This certainly isn’t the first time you’ve went down a rabbit trail while indulging in adult beverages and left handed cigs. You make zero sense when you write like this and there is absolutely no technical anything added to the discussion. Lots of guys end up mad and you in reality are embarrassing yourself. Ask your brother there to turn your device off your typing on til you sober up. Your better than this Smoke.
Old Jan 4, 2020 | 10:52 PM
  #262
Luv U Velle get that done 4 U & me. U Know!
We are good...
Old Jan 8, 2020 | 04:06 PM
  #263
fnbadaz06's Avatar
Originally Posted by rkupon1
So, i was talkn with Darth couple days ago, n im alil more confused than before on drivetrain loss? How are you guys calculating it. I thought it was a percentage of sorts. His math works out alil better in 700hp area. But its defly not linear answer. Just curious on some of your thoughts. I get its easy to figure out an exact percentage once you see rwhp numbers. But where one formula works, its totally off on another set up. I thought a 700hp ish build with a 4l80e n ford 9" would lose about 20%. I figure converter slip will also have huge factor.
It's DEFINETLY not linear. A C6 Z06 with 505 crank HP SAE is around 445-454 on a chassis dyno, or roughly 60-65 HP driveline loss. A 600 RWHP C6 Z06 is roughly 660 crank horsepower.
Now, if you start changing transmissions (auto from manual), convertor in an auto,diff, rear axle ratios, etc. , you can be introducing additional drive line losses.
Old Jan 8, 2020 | 06:06 PM
  #264
Mickyinks's Avatar
Mine hits the dyno today and hoping for between 800-850hp.
Old Jan 8, 2020 | 07:25 PM
  #265
Darth_V8r's Avatar
Moderator
Results?????????
Old Jan 8, 2020 | 08:25 PM
  #266
Mickyinks's Avatar
Results?????????
As soon as i know results i'll post .....
Old Jan 8, 2020 | 10:10 PM
  #267
AINT SKEERED's Avatar
In for results
Old Jan 8, 2020 | 10:25 PM
  #268
bortous's Avatar
Originally Posted by AINT SKEERED
In for results
Same with me.
Old Jan 9, 2020 | 12:52 PM
  #269
Double06's Avatar
On the driveline loss I think Lingenfelter did some test on a C6 Z06 and say it was 65 hp or 13% on a 505 hp motor. They saw it was not 65 hp through a higher HP motor but say on a 700 hp motor it might have been an 80 hp (say 11%-12%) loss even with same drivetrain. It has to due with more torque motor puts out the more frictional loss as the torque is digging harder into the trans and rear gears thus creating more friction. I think it is like a mix of fixed and variable losses.
Old Jan 9, 2020 | 03:38 PM
  #270
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Did some cleaning up on this one.
This is a tech section so let's keep things on track going forward, otherwise we'll just have to shut this one down.
-Admin.
Old Jan 10, 2020 | 07:37 AM
  #271
lazerlemonta's Avatar
i hate seeing no updates from a dyno day........ Hoping for the best.
Old Jan 10, 2020 | 10:23 AM
  #272
Im hoping all went well
Old Jan 10, 2020 | 03:38 PM
  #273
RPM WS6's Avatar
More clean-up today.
This will be the final request to keep things on track/tech focused, otherwise the thread will simply be locked.
-Admin.
Old Jan 10, 2020 | 07:28 PM
  #274
ramairws6's Avatar
Oh man....please don't lock this post!
Old Jan 13, 2020 | 04:37 AM
  #275
Mickyinks's Avatar
Will have some results tomorrow hopefully.... It hasnt blown up i know that much...
Old Jan 13, 2020 | 07:26 AM
  #276
Darth_V8r's Avatar
Moderator
That is preferable to having blown up for sure...
not even a HINT?????
Old Jan 13, 2020 | 08:01 AM
  #277
Mickyinks's Avatar
Not even a hint!!!! Dyno operator didnt go in to work today so i was unable to talk to him..... Im already happy with how the butt dyno reads
Old Jan 13, 2020 | 08:04 AM
  #278
Darth_V8r's Avatar
Moderator
Slacker. Doesn't he know half the internet is waiting???
Old Jan 13, 2020 | 11:18 PM
  #279
Mickyinks's Avatar
ok, record for a N A build on tuners dyno 664 rwhp still more to come as it was 95f when 664rwhp popped up
super stoked , will throw e85 at it and get my goal
Old Jan 15, 2020 | 10:18 PM
  #280
Johnnystock's Avatar
Wow that's badass!! Great build and I love the car! Congrats on the numbers!!
