Ls3 c6 build questions
Ill wait for more opinions on the hg then.
Yeah ysi or novi would be the ideal. Pd would be fun but too limited.
Im pretty good at buying once. Well see.
I'm partial to centris. I like my pd blower on my truck but you'd need a 2650 to really have some fun lol.
Good luck. It will be a fun build for sure. Lazer has had some fun with his. I know with bolt ons, rockers and a tiny clutch that thing was a rocket. I couldn't imagine with some bolt ons and 8psi
Also another academic question. I know compromise choices usually suck at both but would it be possible to get an na cam that does well with a centri? The ls2 c6 I had claimed to have a "blower cam" and it ran okay. I understand pure na performance might fall off.
Any more input on the cam possibilities? @Darth V8r
The Titan King will chop harder, but will want other mods to respond well. Gear for one, looser stall for another. You'd be dumping a lot of unplanned money into making a $450 part work right.
If boost is something you'd be thinking down the road, the Titan 3 is also a decent boost cam. We could talk about something custom, but in the end, we'd be splitting hairs. But for example, you could split the difference between the two cams and get a 230/240-113+3, which would put overlap at 9 degrees vs 6 or 13. But I tend to find that I am never happy with a compromise solution. They're like sporks. Don't really to the fork or spoon thing particularly well, but kind of does both OK.
Most of the time, a person says they want a street/strip car, they are actually happier with just an aggressive street car.
Best thing you can do is be brutally honest about how you plan to drive the car. I promise you, six degrees of overlap in a LS3 is going to have a noticeable idle, so don't go overboard just because you like a sound. But if you also say you really don't mind the car being a PITA, and you definitely want the bigger cam, then go for it. You're the one that ultimately needs to be happy with it. And no matter which you choose, people on this site will help you the best we can to get it to run good for you.
Now to figure out ancillaries. Half *** tempted to buy hptuners to self tune. My former boss is a tuner whos willing to walk me through it. At least on the NA tunes. Have a dyno local I can rent also, the tuner who owns is just sort of iffy for me to tune my car.
Meant to say -- don't rent the dyno until after you have dialed the car in well on the street. Two reasons. It'll be loser overall, so it's less to deal with. And the practice will ensure you don't waste time you're paying for trying to figure out the paste-multiply or wideband inputs.
