Tusky's Cookbook~All motor builds
#81
I have a base model. It had NPP and forged wheels as options. It really would not be hard to get to 29xx with race brakes, removing air bags, steering wheel, passenger seat etc. I just choose to keep it an intact car. Last time I ran it I had a full tank of gas and tried dumbbells for ballast lol
The following users liked this post:
DavidBoren (12-04-2020)
#83
#84
#85
#86
Moderator
Received 1,838 Likes
Already dual exhaust. More efficient drivetrain. Less intrusive cowl.
#88
Ive had a 4th gen Fbody, 2 5th gen Camaros and a C6 that Hiossilver and I have done all the work to. Hands down C6 is the easiest to work on and make go fast. We took my C6 to 11.0 @ 125-126 with 100% stock exhaust and basic bolt ons and didnt even have a complete poverty drag pack lol
HioSSilver (01-20-2020)
#89
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
In the late model Corvette world, 9's are the new 10's, which is quite a feat for a manual transmission car with an IRS rear suspension that's not designed to be drag raced in 1/4 mile racing.
The following 3 users liked this post by fnbadaz06:
#90
Moderator
Yeah corvettes are cheating lol.
#92
Looks like lazer and darth splained it pretty well.
irs is a good thing
Worst part is not being about to get enough gear in them for high rpm engines.
I generally agree with this, though I guess we need to define what the "next level" is ![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
#94
We finally got the options for 3.90 and 4.10 rear gears for the stronger Z06/ZR1 cases, which will help a lot....many went the option of changing transmission gearing to accomplish torque multiplication, but Vette drive lines are just not designed with 1/4 drag racing in mind.
Tuskyz28 (01-21-2020)
#96
Moderator
Originally Posted by ramairws6
No need for a solid roller. 750+ on the crank dyno here and still hydraulic ![Huh](https://ls1tech.com/forums/images/smilies/LS1Tech/huh.gif)
#98
swapped.to a 200-4r and 3600 stall and slowed to a 11.60 at 118. Sent converter back and stalled it to 4600 to get back to high 11.3s.
changed 241 heads that had mild port work to Darts hand ported. Picked up 26rwhp and went 11.21.at 121
changed converter to a 5600 8" fti to go 10.91 at 122 at 3850
honestly I dont think with this 4l80 and 8" converter I have behind this 427 is any quicker than I'd be with a 6spd manual. And on the street I was out running all the automatic cars who had to pedal to much. When you know how to drive a manual, launching it and rowing gears it's hard to beat.
I only went auto because went through clutches and my rear gears howled like a banshee
#100
In my world, auto swapped C6 Z06's pretty much decimate any manual car with equal power......just no way around the need to slip the clutch on launch and the loss of power to the rear wheels when you have to hit the clutch 3 times in a 1/4.
1/4 drag racing is all about the first 330' (with regards to ET).......auto swapped Z's run mid to bottom 1.3 60's easily, and are pretty much high 9 second cars right from the get go.
They'll give up a few MPH in trap, but that doesn't matter when 1/4 drag racing is all about ET and getting to the finish line first.
There are some tricks we can do to help the launch and speed the shifts up....even some have run face plated trans, but it's very difficult to make up the advantage on the short times the auto can have on you.
Now roll racing and standing start 1/2 mile and longer is a whole different story.
