04 GTO ls1 CAM options
What compression are you at?
Are you auto or manual?
I need a bit more info before I can give you a recommendation,
With 8 degrees of overlap, it will have a choppy idle in an LS1.
it will do what it says.
i had a camshaft from Ed Curtis once.
It made killer power for a small camshaft.
I've been looking into cams, and it seems 228/232 .600/.600 112 LSA seems to be a very popular choice with LS1. Any other advice? In terms of what overlap I want in a cam that will work well with 799 heads.
the SS-HT has 8 deg overlap, which should give you some really nice power. I wouldn't go too much bigger than an SS-HT on a 5.7L that is being street driven. The cam spec you suggested has 6 degrees. Kind of close to call. I would give a few good cam grinders a ring and see what they say. You never know, you might end up going with different specs to actually give you less so it is better to drive. FTI makes an SS-TQ that has 0 degrees of overlap, 220/224 .597/.592 111 lsa, supposedly makes good power for the size cam it is. should have excellent manners, too.
You're going to want to trap 117-118 to hit solid high 11's in a manual GTO, though, so factor that into your calculations.
