Oil pressure random drop
Old Feb 22, 2020 | 02:20 PM
ffjosh's Avatar
Default Oil pressure random drop
6.0
bored .040
Brand new flat top pistons
ported meling pump
Small cam
New valve train
Idle cold 55 - 60 psi
idle hot 40 psi
Did two 10 min idle warm up cycles no issues.
Weather changed and I was able to drive it today
2500-3000k 70 psi
around 1k 40ish psi
after about a mile which included stopping shifting rpms ranging from idle to 3k (under 50 mph and under 35% throttle) I stopped as I noticed I lost a tool in the road. It sat and idled for about 5 mins.
when I got back my check oil warning was on and it was at 7.8 psi! I drove it down my long driveway around 1200 rpm and it never changed.
No noises, gave it a little rev when I parked it (1500 rpm) and still 7.8.
When I looked back at the data log @2700 rpm I had 72 psi
Later @2700 it had 45 psi
Idle went down to 12 psi
Running 5w30 valvoline for the break in with a wix filter. Any ideas?
Old Feb 22, 2020 | 02:24 PM
ffjosh's Avatar
I'm going to pull the oil pressure gauge and make sure it didnt get anything in it. My first oil change had some sparkles (seemed normal for a new engine)
Rear main seal is leaking a little. It was leaking a lot but I fixed most of the leak with a better pvc system. Now it's just a few drops.
Oil is right at the full line.
I was thinking of adding a extra quart (bring it to 6.5) and see if that helps
Old Feb 22, 2020 | 05:38 PM
SLP IROC-Z's Avatar
cut the filter open
Old Feb 22, 2020 | 06:48 PM
01CamaroSSTx's Avatar
Running the stock gauge and sensor I take it.
Check the oil pressure sensor and connector first but that sounds like something went terribly wrong.
Old Feb 22, 2020 | 09:42 PM
ffjosh's Avatar
Filter is fine
new gm sensor (20 mins on it) using hp tuners to tune it.
Connector was fine I'll get the sensor off tomorrow
Old Feb 22, 2020 | 10:27 PM
SLP IROC-Z's Avatar
pressure relief valve might be stuck in the pump
Old Feb 23, 2020 | 12:29 PM
ffjosh's Avatar
I could not get the oil pressure switch off (my deep well is not at home) so I filled it with 6.5 quarts just to be sure. Check all the lines, fuses ect.
Oil pressure said .8 before cranking
Started it and it still said .8
After 5 secs I turned it off
oil says -2.2 now
started it and still says - 2.2.
said *** it and let it run 10 secs. Went from cold idle 1100 to 800 and never changedchanged it off.
I should have my deep well tomorrow and well investigate.
Old Feb 23, 2020 | 01:23 PM
Do not start the car again. I’d put money on it being the relief spring in the pump. Happening here lately to a couple folks. It’s a boat load of work, but if it were mine, I’d pull the oil pump and take a look. It’s visible through the window on the back side of pump.
Old Feb 25, 2020 | 12:22 AM
ffjosh's Avatar
Been searching but any way to test the oil sender unit? Ohms test I would guess
Old Feb 26, 2020 | 01:10 PM
KT35's Avatar
Originally Posted by ffjosh
6.0
bored .040
ported meling pump
Small cam
New valve train
idle hot 40 psi
2500-3000k 70 psi
around 1k 40ish psi
Who ported the oil pump?
single or double row chain?
Old Feb 26, 2020 | 01:24 PM
WE TODD DID's Avatar
Put a mechanical gauge on it and check.
Old Apr 10, 2020 | 05:28 PM
ffjosh's Avatar
Put the oil sender on another car and read fine
pulled the engine and found silicone on the screen.
Mjust of came loose after I drove it
Old Apr 11, 2020 | 08:16 PM
ffjosh's Avatar
I lied oil pump relief valve was stuck (not due to debri) fixed it but I'm changing out all my bearings. One was a little sketchy
