LS7 block on truck style heads.
Old Apr 6, 2020 | 08:30 PM
jojo_3663mk3supra's Avatar
Default LS7 block on truck style heads.
So this is probably far fetch. So I might be getting a ls7 block and I know I can bolt up any LS head to it but I was wondering if anyone had any idea what the power would look like if I was using my 706 heads on the block. I was wondering if I would be loosing power.
This engine would be going in a mk3 supra.
Old Apr 6, 2020 | 08:35 PM
AgFormula02's Avatar
That head choice is not optimal. Yes it will work but you will leave power on the table.
Old Apr 6, 2020 | 09:04 PM
At the very least get them ported with 2.02 intake valves and bigger (at least 1.570") exhaust valves.
Old Apr 7, 2020 | 11:12 AM
Jimbo1367's Avatar
Would the chambers be large enough for the piston stick out above deck?
Old Apr 7, 2020 | 11:35 AM
Darth_V8r's Avatar
Moderator
if the pistons are dished, it's fine. Head gasket thickness will take care of that. if flat topped or domed, you must be running very high compression, because the chambers are so small. If you are, you likely will want custom pistons so you can specify exactly what you want.
Old Apr 7, 2020 | 12:41 PM
WE TODD DID's Avatar
100hp down from an ls7 head.
Old Apr 7, 2020 | 05:22 PM
00pooterSS's Avatar
If you need to ball on a budget I would at least get rid of those heads and cathedral intake and do LS3 heads and intake, you can find them used pretty cheap and would be a much better combo
You'd also keep the 11.0:1 compression since LS7 heads and LS3 heads share a 70 cc chamber.
With the 706's on the LS7 you're looking at 12.2:1 which is pretty high. Can be done, but needs to be done right.
Old Apr 7, 2020 | 09:17 PM
thanks for the info I’ll see if I can sell my ls6 intake with the heads and do the ls3 heads and intake.
Old Apr 8, 2020 | 01:43 PM
00pooterSS's Avatar
The ls7 should run really good with a ls3 top end. Way way better than the 706 head setup
Old Apr 8, 2020 | 05:47 PM
64post's Avatar
Yes, at the very least get a set of 823 heads and truck/LS3 intake. Could be had for not a lot of money and way, way more in line with that 427 short block, just sayin, also.
Old Apr 8, 2020 | 05:48 PM
64post's Avatar
706 crack heads? Not even the best 5.3 head imo.
Old Apr 8, 2020 | 07:07 PM
Darth_V8r's Avatar
Moderator
Lolz!
Old Apr 11, 2020 | 08:43 PM
00pooterSS's Avatar
Agree. Richard holdener did a back to back of a LS3 intake and a rectangle port truck intake and they dynoed the same, like identical the same..
Old Apr 11, 2020 | 10:25 PM
bortous's Avatar
An LS3 top end is a good suggestion.
I would also suggest to get a set of 243 heads and have TEA do their stage 2 port and valve work.
With around 330-340cfm on a 4.125 bore and with a 229cc intake runner, the engine would be super responsive and torquey and still make a good top end number.
But you would need to run a Fast 102mm cathedral intake as the ls1/ls2 gm intakes are junk.
