Quiet Cam Help for LSX454
With that, madam chairman, the ******* from Texas yields the remainder of his time.
I get the feeling you are a bit pissed off/annoyed with the way the engine idles etc and just want it to drive smoothly.
I wouldn't think your current camshaft would be that bad in a 454.
Mick had a 239/254 114 LSA in his 454 and this drove great and his car is also manual.
This is with 18 degrees of overlap.
The absolute smallest I would go in that size engine is the 242/254 117LSA+4 camshaft I mentioned before.
14 degrees of overlap is NOTHING for a 454 and any competent tuner should be able to get it to drive very smooth with zero bucking/surging with a manual transmission.
With your compression also, it makes more sense to run a camshaft to suit.
With aftermarket cylinder heads the air speed etc would be higher which in turn helps with driveability when using larger camshafts.
I guess what I'm trying to say is, don't get me wrong it drives great now actually, but the idle sound is too too much. I guess that is exactly what cams do. More air in + more air out = Louder engine.
I heard Z06 with nothing but headers and they sound beautiful at idle. You know that low Magnaflow V8 rumble. Its sexy. and doesn't sound like a 70s car.
Might sell the whole engine and have LME build me one for boost. Twin turbo will be from UPP.
The OP has made very clear his tolerance for idle BS. I have worked with people who had -6 (negative six) overlap cams in 408's and STILL felt the cam was too choppy. I have also seen what 16 degrees overlap does in a 427, and it will still have some chop to it, and you can't tune all of it out. Yes a 454 will absorb some of that, but it won't suddenly make it act stock. And as to relying on tuning to tame a cam, go read the PCM section to find all you need to know about how often that is truly successful. Good tuners are getting rarer.
What makes speccing cams for other people so difficult is that it is difficult to avoid super-imposing your own preferences into the equation. This is a case where you err on the small side. This is not a customer who is going to potentially complaint because the cam left 10 hp on the table, but does have the potential to complain if the cam is still choppy after doing a cam swap.
It sounds to me it's the surge the OP wants to get rid of going by the tone of his post.
I don't think he means he wants it to sound like a 100% stock engine.
Stock like characteristics can mean different things to everyone.
14 degrees of overlap is nothing though.
It will only have a little note but drive smooth with a competent tuner.
Going from 28 degrees overlap to -1 is a huge change.
OP, can you elaborate on what you mean by stock like characteristics?
If you are wanting something with negative overlap, lower overlap etc...
Or do you just want to get rid of the surging as your main focus with a smoother idle than before?
LS7 cam - 210/230-120-3 (that's MINUS 3)
Made Up - 230/230-115+2
VE-------LS7---------230/230
IVC........48...............48
IVO......-18................2
EVO.......52..............52
EVC.......-2................-2
Three out of four valve events are exactly the same. The only thing that changes is the intake valve open. So, is the wide LSA the issue, or is the tiny duration on the intake lobe the real issue? Or.... Is the intake valve opening too late, resulting in BOTH the wide LSA and low intake duration?
KW
