LS2 Inake manifold
I also had a chance to acquire protoype pieces. The prototypes still had the MAP at the rear of the intake manifold and looked like they were made out of a different material. Other than that they looked to be the same. I know the internals were the same.
For all you guys that are worried about installing it, I have o-rings that will work with stock injectors so that isnt a problem. Also, about the fuel rail, talking with another guy, he said something about shimming it up 300 thousandths at the mounts with a washer would allow stock fuel rails to mount with some small modifications to the fuel rail. I might play with this later today or tomorrow and see what I can come up with.
Nice to finnaly see this thing!
Brad
Talking to another shop that has been testing this on an engine dyno had found some interesting results.
From back to back runs between LS6 and LS2 here is what I was told
Stock motor: pretty much no gain except for a tiny increase past 5,000 rpm of a couple of horse
stock cubed motor, aggressive heads/cam: small increase through powerband, and about a 7 to 8 hp increase past 4500 rpm
big cube motor (im assuming 400+ cid): nice gain thru powerband and up to 17~20hp past ~4200-4500
Now remember, these figures are on an engine dyno so you have to calculate in drivetrain loss to find RWHP gains.
Also, someone commented that the FAST TB is 5 bolt, the top bolt isn't used on the LS2, but the other four bolts are in the same location and it bolts up with no problems.
It looks like the prices on the LS6 intakes are going to steady!!
This post is acting kind of funny.
Most of the pics are self explanatory.
On the intake ports, you can see how some mated up almost perfect and how some have a wall on one edge. This is a result of the friction welding. But the good news is, this process has already improved quite a bit from the preproduction models I've seen and it should keep improving as time moves on.
The intake port gaskets are the same, although they are a new material hence the different color. Also, you can see how much thicker the o-rings are.
And on the back of the intake, one of the vaccuum line connections had broken off, but this can be fixed by plugging it and running a T off the main vaccuum in the back.
It doesn't look like there is much of any gains with this intake or the F.A.S.T. intake on an all motor car. What about forced induction or a nitrous 408ci iron block with good heads and cam?? Thanks for your input.
Keith
