Too stroke or not to stroke!?
what ever you do, please do the research 1st. Patrick g does a great job with cams for ls3 heads if you go that route
torque under my current setup is really lacking, top end speed is underwhelming also. I still want the reliability, but I’m looking for a lot more HP and torque now. That’s why I figured I’d build a 408 instead of just the standard 6.0. But if the new setup can run in the Tens and I can still use the car to make a 3 hour run to the Florida coast I’d be excited. My friend has the 6.0 block and the 823 heads, and I have my Ai ported 243’s, I’m just tryna figure out the best combo. Also, I saw texas speed has a 218/221 stroker kit for the LQ4/9 setups should I be considering that also if I don’t ever plan on forced induction?
going to the 6.0’s Now, I’m not happy with the low end torque. The money I spent rebuilding the engine I could’ve done the 408 years ago. Nah they can’t hang with the setup, even tho there’s more too end to be desired also.
One thing I will say is you could not pay me to run stock ls3 heads if I had access to A.I church ports!! Stroke or throw some pistons in that lq and have fun. You can make 500rw easy without stroking and those heads. But those heads and a 4xx stroker be a tq monster.
The other place the guy was really thorough asking questions about the studs I’ll be using, whether it’s ARP or not, and honing with a deck plate or not, benefits to honing with a deck plate. Here’s his prices belowARP line hone $245
Bore and hone W/O deck plate $310, W/deck plate $400
Parallel deck block $100
Notch block for HBeam rods $200
Clean block , galley plugs $190
Balance rotating assembly $285
ARP studs $240
