Too stroke or not to stroke!?
So is it worth the expense and trouble, how much more Power could I expect the setup
to make?
help a 408 breathe. Personally I would with a 408 build at the very least go with ls3 heads and intake if I’m a budget and maybe a btr cam. If you look at the sticky called tuskys cook book https://ls1tech.com/forums/generatio...or-builds.html
it has a huge amount of great info on stroker builds. There’s a couple of 408s with ls3 setups on them making killer power. Then a couple of 408s with badass cathedral port heads running awesome times
help a 408 breathe. Personally I would with a 408 build at the very least go with ls3 heads and intake if I’m a budget and maybe a btr cam. If you look at the sticky called Tusky's cook book https://ls1tech.com/forums/generatio...or-builds.html
LS3 intakes cost about $250 bare and new.
LS3 heads are $500 used.
That gives you an idea of costs.
and just upgrade your existing cam (something like~ 237*/243* 112*+3* rowdy, 114*+3* mellow, .620"/.610")
The 4" stroke and +60" will drive just like your current combo with a good tune. ~11.2-11.7:1 comp,
depending on 91 vs 93 octane, combined with .035-.040 quench,
(Obviously get with Cam Motion or Darth to really spec you a cam for your goals, not a cam guru...
just like to play one on tech.) lol
Make the same HP and broader torque curve due to higher port air speed, ~600 HP @ Crank & ~520 lb'
500 RWHP & 440 LB' with wicked throttle response everywhere. For what you are looking for and
budget you have great heads and intake for 4.030" Bore and sub 7000 RPM street/strip car fun driver.
You need more rpm and cam to utilize ported LS3 heads IMO.
Or mill LS3s clean up exhaust side a bit , your existing cam would work pretty good with the much LARGER ports,
260 cc VS 230 cc for close to the same air flow ~ 315 CFM enough for 640+ HP @ Crank.
Just my .02
Good Luck
torque under my current setup is really lacking, top end speed is underwhelming also. I still want the reliability, but I’m looking for a lot more HP and torque now. That’s why I figured I’d build a 408 instead of just the standard 6.0. But if the new setup can run in the Tens and I can still use the car to make a 3 hour run to the Florida coast I’d be excited. My friend has the 6.0 block and the 823 heads, and I have my Ai ported 243’s, I’m just tryna figure out the best combo. Also, I saw texas speed has a 218/221 stroker kit for the LQ4/9 setups should I be considering that also if I don’t ever plan on forced induction?
