Johnson lifter failure
I have Johnson 2110r lifters with less than 8k miles. I had one fail, not blaming Johnson lifters I believe it was the lifter tray (tray was brand new). Johnson is sending me a new replacement. Would you replace all 16 or just the one that failed? I’m putting in a new cam with new trays. Trying to decide to just send it or put all new ones in. Thanks
If this is the case with you, you can fix it now.
Might be worth considering if you are hesitant to go back to a plastic tray
In the end, it's just easier to run a tie bar lifter.
Even the early GM and Ford hyd. roller lifters had a sheet metal "spider tray" to hold the dog bones in place. https://www.summitracing.com/parts/e...yABEgLP0PD_BwE
And the block has to have "flat pads" above the lifter bores so the retainer plates sit flat. And the LS does not have an "open valley" to place the retainer plate in anyhow.
