Low compression on cylinder #6
Results- This was a cold compression test near sea level
212 #8 #7 208
173 #6 #5 210
205 #4 #3 203
194 #2 #1 200
18.4% diff. between #8 and #6
I also did a wet compression test on #6 and got the same results. Is this a bad sign? My air compressor only goes up to 150psi so I can't do a leakdown test.
Obviously it's not the piston ring and it's probably not the head gasket, what else could be the cause besides intake or exhaust valves?
212 #8 #7 208
173 #6 #5 210
205 #4 #3 203
194 #2 #1 200
Id do it warm btw.
I'm a bit of a noob with all this and after a quick search a leakdown test turns out to be a bit different than what I thought, I would have to borrow one from a friend.
