Another LS3
I live kPa, C, kg, N-m, mm, etc etc all day every day at work. Imperial anything can die in a fire. Time to build back better with metric.
One weird thing I could have lived my life never knowing is that GM doesn't drill out the rear two steam ports on LS3 heads. It never even crossed my mind to check that. Since I already ordered the Manton pushrods I'll just live with only the two corners functional. Going to be a bit weird that they are the ones in the back and I had wanted to vent all four but... oh well. I'll just plug the extra ports on the Motion Raceworks manifold I had laying on the shelf from a previous abandoned project. Good thing the only car show it will see is the yearly one at work (Honda R&D). The American guys mostly don't care about a Camaro that turns and the Japanese staff have no idea what they are looking at anyway.
It looks like there will be enough room to put it in front where the battery tray is. I'm going to mount it directly to the frame rail there, with the remote filter mounted to the same location on the inside. Seems like it will be a bit too difficult to fish an M8 bolt all the way back to where it needs to go and I don't really want to use a rivnut. I'm thinking something like these welded on are the answer: https://www.mcmaster.com/weld-nuts/m...ase-weld-nuts/
Dyno is scheduled for April 19th. Should allow time for everything to get sorted.
Oil pan is back on and clears. I had to grind down the baffle louvers for the rod bolt on each of the cylinder pairs. I also hadn't quite cut one of the main studs down enough to clear. Hoping to roll it back under the car this weekend. Also trying the Moog Problem Solver ball joint style front lower control arm bushing. Was never allowed to use it in the old ESP days. The stock style ones would be absolutely shredded and falling apart after a typical 80 run season.
Still have enough room where even with the slightly taller BFG I still won't have contact at full bump and full steer (something that shouldn't ever happen). Interestingly enough since I've bent the control arm mounting plate from bottoming the car out, the upper arm, the tire to metal fender liner, and the tire to upper fender support rail all hit at the same time. Guess I won't be going back to that lower ride height again until I can pull some weight in the front and go to a spring in the 1400+ range.
XRP does not make a fitting that will let me use the 16an feed in the space I have and with the 10an pump inlet. I can either use their 12+ large bore line or have Brown & Miller make me a line that goes directly from 16an hose to a 10 ORB port. Decision for tomorrow. The only way I've found to fit the Peterson filter between the pump out and filter is to run the line down below the sway bar, then a 120 degree fitting to the filter sitting in the same plane but just behind the radiator. Then it can just make a hard 90 as soon as it clears the frame rail and into the tank, snaking between the radiator hose and the rail. Remote filter will have to go on the front side of the core support right behind the driver headlight. And the only spot I've found for the fuel regulator is on the opposite side of that. Breather can will be in the typical passenger cylinder head spot.
Would make it a hell of a lot easier if I just tube framed the front but that's a project for another shell and another season.
I would say I'm excited to be done wrenching, but after this I still need to do the timing belt and brakes on the Golf, VANOS/AC compressor/window regulator/weatherstripping on the M3, and battery relocation on the RX8.
Tried to fire it today and it caught for a bit but didn't stay running. After looking at the tune I had some settings wrong so I'll try those changes tomorrow. I was at least able to verify no leaks and 80psi at the oil filter. Pretty sure I have the wrong factory pressure sensor in it so the dash gauge (functional 98) is pegged hard right. Looks like I'll have to back the adjustment screw out a bit on the pump to get it closer to 70psi. It did pull the tank about a quart lower once things really got moving, so that should give it more room to expand. Flex sensor wiring is also working and reading E60 with the gallon or so of 93 left in the tank and ~12 gallons of pump E85.
