Another LS3
Old Aug 5, 2022 | 09:43 PM
  #81
landstuhltaylor's Avatar
So for those following along the path is at least set, it's getting an ECU Masters PMU 16. Sadly it will be over the winter as there just isn't time to get it done and tuned by the 25th.
The Smartwire is pretty locked in to the Holley ecosystem and other CAN units are very limited with the Racepak CAN channels. Haltech just came out with a PDM but currently there is no way to run it without also using their ECU, although it sounds like this will change in the future. That effectively leaves Motec in the PDM space. The ECUM unit has one extra channel, can PWM it's 25A outputs (the Motec cannot), and is otherwise pretty identical. It can also fool an M1 ECU into thinking it's an actual Motec PDM. Seeing as I want to leave the door open to using an M150 ECU, and it's ~$1700 with a keypad vs $2500 for the Motec system, that's the route I'm going.
Should allow me to program all sorts of safety logic in the power distribution as well as completely eliminate the ignition key and replace it with a code entry on the keypad. If I hide a switch in an odd place as well as have the key pattern to allow the master power, should at least be effective as 90s GM anti-theft for the very very few times it gets parked in public.
In the mean time I'm most likely driving the Civic at KoTM, which is also what I'll be driving at Nationals. Only ~235whp on a Mustang dyno but 2730lbs so it's likely quicker than the Camaro through the tight infield section. Definitely won't win but at least I can play spoiler, and it will be good seat time for Lincoln the very next week.
Old Aug 9, 2022 | 12:05 PM
  #82
79_T/A's Avatar
Have you looked into the PDM from AIM or does it not play nice with the Holley?
Those generation Si’s are great cars. Best daily I’ve ever owned. Regret selling it.
Old Aug 11, 2022 | 01:05 PM
  #83
I looked at the AIM ones but they are really optimized around using their dash, and they don't have a price advantage any more. Aside from being mildly compatible with almost everything, they don't do anything amazingly well. And it still can't read the Terminator CAN because you can't output it without an HP or Dominator ECU.
The Civic was a great street car until we ruined it with 1100lb springs and a clutch diff. With the bigger turbo on my diesel Golf, I can't justify buying the Civic even with the company discount. The MK6 isn't quite as nice inside, but 200whp 340wtq and 47mpg tank average is still a good daily. Pretty damn stinky even with the high flow cat though...
Old Aug 13, 2022 | 09:53 AM
  #84
1bdbrd's Avatar
I would love to read about the swap to the PDM. Ever since I learned about the SmartWire and PDMs in general I have been itching to swap my car as well. Mine is more of a street car but I feel there's a lot of weight to be pulled in wiring and fuse blocks but still have everything work near stock.
Old Aug 17, 2022 | 09:36 AM
  #85
There's a lot of weight to pull, a lot of space to gain, and a lot of reliability to be had over 20+ year old wiring. I've started to accumulate used tools from Ebay for the job including a Daniels AF8/TH1A crimper for less than half of new. It seems like once I have the tooling the Deutsch connectors are cheap enough there is no excuse not to use them everywhere on all the cars I own.
Went to the CAM event over the weekend. The Civic is off the pace of a good CAM-T car, but I was still able to raw time Strano and his 4th gen in the afternoon on Saturday (he beat me in the morning). Sunday my car owner had to leave early, so I hopped in Nathan Popp's ~680whp 4th gen. Between the on/off switch on initial throttle tip-in, the wet but drying course, and the old 315 Rivals the car was a handful. I was at least able to get it within a half second of Strano on my 3rd run and probably could have caught him if I hadn't screwed up the last turn. I know I would have been faster in my own car but if Nathan can smooth out the throttle and get the front of the car to do anything, that won't be the case.
Old Oct 6, 2022 | 08:18 AM
  #86
Bit of an update: the Holley system will be for sale.
The ECU Master PDM is here, it's literally the size of my hand and will replace every single fuse in the car except for the ABS power supply. I could probably run that too if I really wanted but I decided not to. Current exchange rates also mean I couldn't not ditch the Terminator X. Once Motec catches up on manufacturing there is an M150 ECU and C127 dash on the way. Really excited to play with some of the more advanced functions like traction and launch control, as well as just really taking the time to plan the entire electrical system. Going to try to build the harness out now with future upgrades in mind.
Can't post the links, but I'd suggest looking in the UK if you wanted ECU Master parts and New Zealand for Motec.
Old Feb 19, 2023 | 07:07 PM
  #87
JimMueller's Avatar
@landstuhltaylor Hey Devin, have you spoken with Jason Swindle recently? I need my shocks refreshed and I'm having trouble getting a reply from him. I think you got your Penske's from him as well? Do you know if another rebuild shop can rebuild them as designed by Jason originally?
Old Feb 20, 2023 | 07:10 AM
  #88
I have not talked to him in a while, but I can give him a call later today. I know there was some point a year or two ago where his email wasn't working for some reason. My second preference would be Shaftworks USA. Owner formally built differentials at OSGiken and quit to build shocks, but still has a working relationship with them. Has his own line of coilovers but also services and rebuilds all of the big names like Penske, MCS, AST etc. Also another autocrosser with multiple championship wins.
As for the thread, still no update. Life is busy and Motec ECU orders are still being backfilled from July. I do have the dash and PDM working together on bench tests though.
 Michael S. Palmer
