What oil for cam only LS3?
An ideal break-in procedure will include heat cycles with varying rpm and load. I like to start it up and go to 2000 rpm for 5 minutes (20 minutes with a flat tappet cam). Shut it off, and let it cool all the way down. Then start it up again, and start varying load and rpm. Go out in 2nd gear and hit it WOT from 2000-4000 rpm and then coast in gear back down to 2000 rpm. Repeat 20-30 times. You can be tuning during this period as well. Then shut it off and let it cool all the way down again. Then I change the filter only, not the oil. You can change the oil if you want with fresh break-in oil, but it's not really necessary. I then go 100-250 miles and then change the break-in oil and filter for the oil and filter of choice. It's fine to use synthetic past that point. If the break-in is done properly, there's no reason to keep using conventional past that point. Remember that during the break-in, you want to keep the engine under a load and the rpm up. You don't want to let it idle.
The appropriate viscosity for the engine depends on 3 main factors: the operating oil temperature, the rod and main bearing clearances, and the load placed on those bearings.
Zinc is a short term referring to zinc dialkyldithiophosphate (ZDDP), a trimolecular ester comprised of zinc, phosphorus, sulfur, and various alkyl groups and used widely as both an anti-wear and anti-oxidant additive. ZDDP is not a single additive, but rather a family of additives. There's ~200 different ZDDPs out there that all behave a little differently. The type found in modern API CJ-4 and CK-4 HDEOs (like Rotella T series) is a less reactive primary alkyl ZDDP designed more for anti-oxidant use than anti-wear. It's also less damaging to DPFs. Modern API SN, SN Plus, and SP PCMOs use a 70/30 secondary/primary blended alkyl ZDDP for better stop and start protection and higher rpm use seen in gas engines. Break-in oils use a highly reactive secondary alkyl ZDDP for initial tribofilm establishment and dedicated racing oils (Driven XP series, HPL BAS) use a similar secondary alkyl ZDDP but with higher thermal stability. The type of ZDDP used in aftermarket oil supplements is largely unknown and can vary depending whatever type is cheapest at the time.
Zinc (ZDDP) is a boundary film lubricant added to the oils anti wear additive package. Zinc reduces metal to metal contact and also minimizes lubrication breakdown. Zinc is VERY important during break in for flat tappet camshafts and continued film lubrication after break in. Today's roller camshafts don't need as much zinc like the older flat tappet engines.
That said, IMO... zinc is still a great anti wear additive especially for modern roller engines with high valve spring pressures. It's drawback's are clogged catalytic converters when used in high concentration over time. It's a heavy metal that has environmental concerns if not disposed of properly. The EPA has reduced the amount of zinc through the years so unless you are adding your own zinc concentration to the oil your cats are safe.
My cats are safe... because I set them free with a sawzall![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
These "what oil" threads always amuse me...
Brings out the "religious" types of attitudes. Every Internet forum, every kind of car, every single time, without fail. Like night following day. Hilarious. Sometimes I wonder if there are other people like me who just like to poke a stick into the hornet's nest and stir it up and stand back and watch what happens.
That said, my preference is for new, fresh, clean, of the OEM's recommended viscosity or very close to it, preferably synthetic; but really, new clean fresh dino skweeezins is better than old crusty filthy synth.
No doubt that Amsoil makes good oils but don't take those PF videos as gospel. None of his tests actually test the parameters of engine oils. The scar test is an old abandoned rig that was designed to determine the scuffing resistance of greases. Putting an engine oil in it is like asking a Prius to tow a school bus. It's way outside of what the oil was formulated for. If you were to go by the original standards for that scar test, every oil he has run in that rig has failed miserably (as expected), including Amsoil. The results are also highly unrepeatable, making any comparison of two oils no more valuable than a coin toss, which is why the rig was abandoned by SAE decades ago to begin with. Even the pour test is useless because cold start performance isn't about pouring but rather is about pumpability. That's why cold start simulation tests are measured in dynamic viscosity (under pressure) using a mini-rotar viscometer (MRV). Two oils could pour at different rates, but still pump at the same rate.
The following 3 users liked this post by Polyalphaolefin:
And there you have it folks....enough guessing and he said-she said stuff. Just the facts from a professional in the industry. Thanks again Poly for clearing up yet another oil thread. Merry Christmas folks!
