FED Tech Series S1Ep1 - Valves
Hey guys, just wanted to update everyone and post a link to our first YouTube Tech Series video on valves. If you guys have any questions regarding valves in regards to shape, dimensions, weights, when/where/why and i'd be happy to guide you in the right direction. Thanks for watching!
The following users liked this post:
anotherTodd (02-02-2021)
It was good. I learned something new. I was not aware that inconel valves where not full inconel.
Can't wait to see the Differences in coatings for valves!
Only Critic would be a closer view of the valves and the different areas so a beginner can see it better. Maybe a marker board with an exploded view or try and get close up picture maybe with a call out of the area's that you could add to the video? I know it's difficult to get the zoom to function properly in a tight area when your trying to make the video. It almost never cooperates.
Thanks for sharing!
Thanks for sharing!
Thanks for sharing!
Thanks for sharing!
When Mike started talking CRN coated and then DLC coating I was like Damn here we go! But it was also said that it will be covered in another video I had to keep reminding myself wait for the Next video on that. MySelf I would like to know How the coatings are applied, when to use each type of coating and the benefits they offer so I am looking forward to "going down that rabbit hole" Also looking forward to the explanation of the different types of titanium and which application's they are used for.
Thanks again for sharing!
Glad to see this Stuff being brought up to the community so everyone can learn and benefit from it.
Grab your Audience and captivate them within a short time frame so they are more likely to pay attention to all the details. If you get too winded, you lose them and they might miss key details.
Of course that's just my opinion.
https://youtu.be/2WUhdAaBUi4
DualQuadDave (02-04-2021)
I have two suggestions that aren't technical, but will make your video series better. (Note: the 1st suggestion has been noted by others. This makes it especially worthy of consideration)
1. Use a 3rd camera/editing for close ups. In this video all of the valve parameters would make more sense to a wider audience with additional close up shots. In the above video, this would prove especially attractive in illustrating the valve seat, margin, back cut(s) nailhead and tulip differences, and other differences, like back angle.
2. Number your videos AND link to others in series in the description. The reason for chronological numbering should be self-evident. However, linking to associated videos partially negates the need for playlists which are only really valuable for users interested enough to seek out your channel and look for this type of bundled content. A bunch of links in logical sequence is just good marketing. YouTube makes it fairly easy to update this data on as needed or globally; use it to your advantage.
As far as margin goes, a few things come into play such as horsepower (heat) being the main one. Margin thicknesses can be played with for a desired stem height or installed height, chamber volume, and even flow.
anotherTodd (02-03-2021)
Interesting about the suggested horsepower ratings of the materials. I'm running a set of your M311's spec'd for Thompson Motorsports. The longblock is rated for 1300hp and the heads have the "Extreme duty stainless intake and extreme duty solid exhaust valves". I'm running a centri style blower on E85 without meth. Currently around the 1000whp range, but plan to turn it up to 1150ish. With 900 miles on the motor, I really didn't have plans on pulling the heads to upgrade the valves. I was under the impression the Inconel were for extreme heat turbo applications. Should I be worried?
What's the price of the upgrade to Inconel?
As far as price, shoot me an email at gavin@frankensteined.net, i don't want to break any rules here.
