HPR 468 peaking to low.
Specs:
HPR 468, 13.5 compression, Tony Mamo Heads 265 heads, hydraulic roller cam 675/.675 lift 262/276 duration 114+4 lobe sep, Carbon PST intake, Holley 105mm throttlebody, 2" headers, E85.
WIth your cam specs being 10 degrees more, hyd to solid, youd think your peak would be higher..
Ive seen a few threads on CF where guys with big cube engines were swapping out intakes from mamo msd trying to get more revs/hp but none of them got much more.
i hvnt tried myself tho so only relaying wht if read
of the cubes is to keep the valve train happier for longer and netting power from that rather than turn a 427 or 440 tighter.
what's your idea?
Could be a plenum volume problem, as well. Do they make a spacer for the lid? Did anyone do a volume calc on what the motor needs? Plenum volume is different than total intake volume, but the two affect each other. Example, I have worked on old school big blocks that ended up flying w/ a way too big carb(Holley Hp1000) on a ported stock iron intake and worked great. Ask anyone, combo was all wrong, lol. The super high air speed and lack of plenum volume created a perffect storm for huge carburation and drove really well and made stupid power for what it was. Basically,, plenum volume needs to be sufficient to feed the "pulse" when the valve opens. Not enough and it starts to feed from the inlet source(carb/TB). It's a balancing act, especially on big motors like yours. That intake was designed around a 400-427in motor, not making the VE yours is. Unless Eric already worked his magic, I am sure there is power there, just playing w/ what you already have. A call to Hogan's may shed light.
Could be a plenum volume problem, as well. Do they make a spacer for the lid? Did anyone do a volume calc on what the motor needs? A call to Hogan's may shed light.
I would think I've got plenty of plenum volume with this intake, it's huge.
Want to make more power then add more air and fuel.
