Solid roller lifters
Old Sep 6, 2021 | 02:13 PM
spanks13's Avatar
I think there’s maybe a canyon type gap in between where people start and end with stuff like this. Billy is the ultimate engineer. He also gets to work with the best racing teams in the world at the highest level. When he can reference things like pro stock and 24hr endurance racing as examples..I don’t think the average guy is getting to that level. Best we can hope is trickle down technology into the aftermarket. Needles are probably “worse” or at least riskier vs their benefits until suddenly they’re better on a perfectly optimized combo AND will stay together.
I think joe blow racing that is throwing parts together off the shelf will likely benefit from a bushed lifter because unless you’re lucky and catch a weird lash adjustment or the needles fall through the engine we don’t have the r&d budget to spintron or dyno test endlessly to get the last bit that makes a needle bearing better than a bushing.
Interesting to read about the advantages though I have to say I’ve never seen a legitimate case for needle bearings anywhere except the rocker arm tip, and I dismissed those thinking that a bushing would be better.
Old Sep 6, 2021 | 05:38 PM
Kurtknarr's Avatar
How do i figure what components that I need? Like springs, I was wanting to run a 1.8 rocker ratio , how do I assure I’m not going to experience coil bind?
Old Sep 6, 2021 | 09:11 PM
Bspeck82's Avatar
you package it with the same manufacturer that made the camshaft
Old Sep 6, 2021 | 10:18 PM
Corona's Avatar
Each cam lobe has a Recommended spring... Working with a certain rocker ratio Size.
As said when you pick a lobe you'd ask that manufacturer what's the recommended open spring pressure, seat pressure....etc. they being someone like comp cam may have a spring but you can use other springs knowing the Pressures needed from the recommendation from the cam manufacturer.
Old Sep 7, 2021 | 12:24 PM
Corona's Avatar
Mike Jone's....Who? Mike Jone's ... Houston Hit song lol...832-830-8004 hit mike Jones on the Low🤣😂
Inverse cams and Billy GodBold's Low Shock Technology Solid Roller lobes.
Mike Jones talks about them also. Who? 832....🤣😂
https://www.yellowbullet.com/threads.../post-73342503
