Optimizing a 460ci stroker
Old Sep 20, 2021 | 01:30 PM
  #81
lazerlemonta's Avatar
Originally Posted by psicko
Whoa momma, that's ugly. It looks like a dynograph from an old peanut port big block. The way that torque takes a nose dive so early, I would think either the valvetrain was set up my Helen Keller or the throttle isn't opening all the way.
If he would have shifted gears at 5250 it would have went in the 10s........good lord that thing is 1960s big block rpm curve.
Old Sep 20, 2021 | 02:00 PM
  #82
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Originally Posted by BigDaddy97
I've ran those runners in the past , you probably won't see a hp increase from them but they will shift your powerband 3 to 500 rpm north.
Didn't you gain 25+ & 3+ mph on your 421" going to Mid-Length runners?
Old Sep 20, 2021 | 02:36 PM
  #83
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Not that low but the car might have shifted too high... hard to say.
Ideally he and the tuner would log a drag pass and see what the converter is flashing too and then also look at the RPM drop on the shift to figure out where to shift it.
Curious on the prior comment about bigbaddy picking up from a runner change.
Old Sep 20, 2021 | 04:29 PM
  #84
Kawboom's Avatar
I dont think this is a case of replacing parts first. Yeah, going to a bigger throttle body would help top end, but the torque curve is mad.
My first thought is torque converter ghosting the torque number way up, and the final power number down, which is what doing chassis dyno pulls with the torque converter unlocked does, and may be flashing the torque converter at the top of the pull, depressing top end torque numbers even further. Even if the torque converter was locked, if you don't have enough pressure or something else is bad you can spin the lockup clutch. The raw data without torque smoothing may show something interesting.
If its real, and not a fudged graph, first thing to check would be the position of the cam, because making that much torque that low with that big of a cam it looks like it is installed WAY advanced. Like put the crank sprocket on backwards, 10+ degrees advanced.
With that cam you could put a set of untouched factory LS3 heads and intake on this engine, and make more power than the graph shows.
Old Sep 20, 2021 | 05:09 PM
  #85
LS1Tech Co-Founder
I heard the cam was maybe just a degree or two advanced. But I agree that's something I would look into. Maybe the cam has advanced ground into it.
Old Sep 20, 2021 | 05:16 PM
  #86
BigDaddy97's Avatar
I did, but I don't expect a big gain on a 4.250 stroke because it will still struggle for air with the 102. My 468 has a 105 and it chokes at 6500.
Old Sep 20, 2021 | 05:25 PM
  #87
ddnspider's Avatar
I've said it 3 times in this thread. It's the FIRST thing worth checking.
Old Sep 20, 2021 | 07:09 PM
  #88
LS1Tech Co-Founder
Okay is the car owner is reading the thread and he can check with the guy who degreed the cam.
 Michael S. Palmer
Old Oct 4, 2021 | 10:49 AM
  #89
ddnspider's Avatar
Any updates?
Old Oct 4, 2021 | 12:27 PM
  #90
fnbadaz06's Avatar
Hey BigDaddy, based on the info shared on Brer's car, what do you think it could make on pump 93? He's gonna check compression, if it's on the high side might be interesting to try E85 or a can of race gas what do you think?
My 468 made 653/557 on 91 pump gas.
Old Oct 4, 2021 | 12:37 PM
  #91
LS1Tech Co-Founder
Any updates?
I think he's got the bigger TB on.
Old Oct 7, 2021 | 05:04 PM
  #92
Brer Rabbit's Avatar
Default 103 throttle body installed and adjusted.
car feels way better but it's hard to know for sure until I get to the track. weather has been terrible DA has been especially high recently. Also I'm waiting on a 5" air intake tube and filter, but it seems ok with the 4" for now.
Old Oct 18, 2021 | 11:08 PM
  #93
racer8088's Avatar
Thumbs up
Got a buddy with a 460 ci stroker:
  • Ported LS3 heads
  • 4.250 stroke engine
  • 242/256 114 cam
  • FAST 102 intake
  • 1 7/8 headers, 3" exhaust
  • stock DBW TB
  • 3.5 air intake
  • 4L80E
  • pump gas
Made 488/610tq unlocked converter on Dynojet, HP flatlined at 5800-6000.
I'm thinking he should move to a 102 TB and a bigger air intake tube, 4" or maybe he can try doing something over the radiator, not sure what fits.
Any suggestions or comments? I also suggested he figure out compression in case it's up there and maybe he can do flex fuel E85 setup.
John,
I really like the oem LS3 heads for budget builds but I have never seen a hyd roller plastic manifold LS3 with any form of oem heads even make 600 rwhp.
Sometimes or should I say we often see 75+ RWHP gains changing to LS7 heads and the MSD LS7 manifold from even ported LS3 stuff FWIW.
The LS7 architecture just destroys all the other ones pretty bad especially the larger the engine gets. Then your problem becomes the small TBs those plastic manifolds use.
With the bigger LS7 intakes like the hi-ram and CID your gains start going from 650+ to 725+ and even higher with 108mm+ TBs and with solid rollers or more compression of course.
The CID sets the tq you can or will make for the most part and the heads and intake set what total power you will make ultimately.
Not that any of that is exactly groundbreaking information or anything.
Old Oct 19, 2021 | 06:23 AM
  #94
ddnspider's Avatar
Nice to see you post Erik!
Old Oct 19, 2021 | 10:23 AM
  #95
LS1Tech Co-Founder
@Brer Rabbit check out Erik's post, he has been building LS engines for gotta be over 20 years now.
Old Oct 19, 2021 | 02:20 PM
  #96
racer8088's Avatar
It's been awhile!
Old Oct 19, 2021 | 02:24 PM
  #97
racer8088's Avatar
Thumbs up
Thanks John! Everyone has had good advice on here but the heads and intake and TB are what it takes to keep the power going up higher in rpm and with the larger engines it's even more of a gain.
It just sucks that we have to have hoods! Of course LME and Frankenstein etc. have some really nice short runner billet stuff too for extremely high rpm stuff or power adders and they will fit under the hood.
They are just kind pricy for us poor people but also do look really nice!
Old Oct 19, 2021 | 03:32 PM
  #98
fnbadaz06's Avatar
Cant wait to try that fancy lid you have to see what the high ram will do
Old Oct 20, 2021 | 04:56 PM
  #99
racer8088's Avatar
Thumbs up
Chris is bringing it tonight so we can send it out to you guys Victor!
Old Oct 22, 2021 | 02:28 PM
  #100
fnbadaz06's Avatar
Yesssssss !!!!!!!
THanks Erik !!!!
