Optimizing a 460ci stroker
https://golenengineservice.com/lsx-c...gine-upgrades/
700hp with ls7 plastic intakes.
https://www.proformanceunlimited.com...-crate-engine/
750+ with AFR LS3's and a sheet metal intake.
I have the build printed out..
https://www.motortrend.com/how-to/hp...parts-lsx-454/
So granted I don't know everything about LS's but the sheet I saw the car stopped increased at 6k, but some might say it was even earlier. So I'm thinking since he ordered the NW 102, will make a 4" air intake, maybe at the same time he can report what springs he is running too? It made 488 on the portable Redline Performance Dyno at LS Fest. I don't see this car hitting 550rwhp unless there is a big spring issue?
Stock LS7's make about 450whp, he's not much above that and there has to be a reason. Is the converter performing as it should?
Is it possible to dyno with it locked?
Very strange graph. Any chance it spun the tires on the dyno?
Does anyone have software to datalog this thing at WOT on the street on a longer pull from like ~3000 rpm to redline? Third gear pull would be ideal.
The induction mods are only going to help, but I'm not convinced there isn't something odd going on.
4" throttle body is a good move. You're probably going to need a 5" air tube feeding it. I also have an old car with filter located in an empty battery tray. Guys like us use long sections of uniform diameter tube and conical air filters, and it doesn't work as good as a lot of people think. Look under the hood of a modern car and you'll see a HUGE inlet that is tapered toward the throttle body. Our little 4" tubes are way more restrictive than that. I started off with a 4" tube and ended with a 5" tube and smooth reducer elbow at throttle body. The 4" tube was really good up to about 500 RWHP and then it started pulling a vacuum. I also have a big *** air filter because the useful flow area of a conical air filter is not as much as it seems. All that stuff can be figured out looking at MAP values at WOT.
The other problem I had was lack of fuel and you might be experiencing the same. AFR readings were fine and injectors were at 70% duty cycle. Huh? Lack of fuel? Yeah, big time. Spark plugs were reading lean and spark plugs don't lie. Installed a fuel pressure sensor and could see fuel pressure drop to ~52 psi at WOT, and a little volcano was forming in the fuel map (Holley EFI) because the ECM was trying to dump in more fuel to compensate for the pressure loss. Again, AFR was hitting target so ECM was happy but the spark plugs told the real story. Upsized my fuel pump and the engine drank +25% more fuel, and that my friend was a whole lot of power. I share this story because lack of fuel can be a little hard to diagnose if you only look at AFR.
Seems like you have enough exhaust for now. It's not optimal but it's also not a huge contributor to your problem.
You also might have the cam installed too far advanced by accident. I did that once and engine HP peaked at 5500 rpm and just table topped out to 7K rpm because the top end could still support the air flow.
Basically I've done a lot of things wrong and it looked a lot like what you've got going on. But I figured it out and you will too.
I heard in conversation the cam was installed a little advanced.
https://accufabracing.com/cfm-air-flow
A 460 c.i. at 7000rpms needs around 940cfms....assuming 100% VE.
Air intake is obviously a pinch point, it's something that will need to be addressed no matter what. Your efforts are not wasted in that department.
It would be useful to now share more details of how you set up fuel delivery (pump, plumbing, wiring). There might be work to do in that department too.
You can't take all flow #'s at face value. You can change the flow # in any direction just by playing with the depression when it's flowed. Just for refernce, I have seen 440/454's pick up going to a 108/112 TB, have even seen gains on top of that w/ dual throttle bodies. Just depends, every combo is different.
