Optimizing a 460ci stroker
Old Sep 18, 2021 | 09:06 AM
  #61
Brer Rabbit's Avatar
Default ...
Originally Posted by TTur1996
When the car gets to 6000 RPM does it slightly break up or stay smooth?
stays smooth. just seems like it doesn't pull as hard as I would expect comparing the big end to the 1/8th mile.
Old Sep 18, 2021 | 09:10 AM
  #62
Default ....
Single intank Walbro or something right? What size injectors. Car is wired up with a Holley Terminator.
Walbro 450, -8 feed aeromotive filter and regulator -6 return
Old Sep 18, 2021 | 10:17 AM
  #63
ddnspider's Avatar
Plenty of pump assuming decent sized injectors.
Old Sep 18, 2021 | 06:42 PM
  #64
BigDaddy97's Avatar
Brer Rabbit, I have the same 4.250 stroke engine as you but with better heads, bigger cam, bigger intake, and a 105mm throttlebody. As expected I make quite a bit more power than you but even so I still flatline at 6500. I talked with Erik at HPR who built my 468 and he said these motors want as much air as you can give them and switching from my carbon pst/105mm throttlebody to a CID Intake/4500 throttlebody will give me 50-60 more rwhp and extend my rpm range a bunch. Do a google search for HPR 468 and read the various threads and you'll see what I mean about the more air the better for the 4.250 stroke motor.
Old Sep 18, 2021 | 07:20 PM
  #65
Z28SteveA4's Avatar
I agree with ddnspider yes the intake upgrades will help but not the cause of the engine coming to a stop like that at such a low rpm range and then tank. We all know stock ls3 head go over 7000 no problem on almost every engine I’ve seen so a worked 460 should smooth sail right past 7000k. You have to have a problem either mechanically and maybe something stupid in the tune that not right. If Andrew is tuning it hard to believe it’s the tune though.
Old Sep 18, 2021 | 07:31 PM
  #66
Corona's Avatar
Originally Posted by BigDaddy97
Brer Rabbit, I have the same 4.250 stroke engine as you but with better heads, bigger cam, bigger intake, and a 105mm throttlebody. As expected I make quite a bit more power than you but even so I still flatline at 6500. I talked with Erik at HPR who built my 468 and he said these motors want as much air as you can give them and switching from my carbon pst/105mm throttlebody to a CID Intake/4500 throttlebody will give me 50-50 more rwhp and extend my rpm range a bunch. Do a google search for HPR 468 and read the various threads and you'll see what I mean about the more air the better for the 4.250 stroke motor.
Same thing I was told about 3 yrs ago
Old Sep 18, 2021 | 08:42 PM
  #67
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Hey BigDaddy, based on the info shared on Brer's car, what do you think it could make on pump 93? He's gonna check compression, if it's on the high side might be interesting to try E85 or a can of race gas what do you think?
Old Sep 18, 2021 | 08:47 PM
  #68
BigDaddy97's Avatar
It's really hard to say. If it were mine and I wanted to keep the stock hood, I would upgrade the cam, port the fast intake and put the interchangeable short runners in it, along with the 103 throttlebody on that he just ordered and the biggest air tube on it he can fit, the E85 will benefit him if the compression warrant's it. My 468 is 13.5 to 1 so I run E85. If he wants maximum power, he will need a different hood so he can fit a CID/4500 throttlebody. Read this this thread, towards the end you will see how he extended the range 350 rpm on his 468 just by using a 112 throttlebody with an adapter plate on his 468: My HorsePower Research HPR 468 build - LS1TECH - Camaro and Firebird Forum Discussion
 Michael S. Palmer
Old Sep 18, 2021 | 09:23 PM
  #69
LS1Tech Co-Founder
Awesome, Gary check out the link.
CID / 4500 would be cool, is that like 4k though to swap?
Old Sep 18, 2021 | 09:37 PM
  #70
BigDaddy97's Avatar
The 4500 is around $600 and the intake is around $1100, plus he will need a hood to clear it. That's what I'm swapping to this winter and it clears my 4" cowl.
Old Sep 18, 2021 | 10:37 PM
  #71
Corona's Avatar
Small problems before the major stuff as you wouldn't see the real Difference...with a intake upgrade
Engine this Big would like a 6500 TB but the problem going this Big is not Having IAC and wanting a street car ..
Old Sep 19, 2021 | 01:58 AM
  #72
TTur1996's Avatar
The only thing that I can think of that would cause that bad boy to be down on power that much with nothing broken could be that both coil harnesses might be flipped backwards. The ones that plug directly into the coils. Purple wire to #1 and red wire to number 2 and laid out accordingly. Worth a shot to check. Usually they break up slightly over 6000 rpm but who knows. The intake may be holding it back a little, but not that much.
Old Sep 19, 2021 | 11:00 AM
  #73
LS1Tech Co-Founder
That's not bad at all, I'm sure we'll chat about whenever we next hang out.
He's trying to keep a balance of having a nice street car he can cruise in with his dad (who bought the GTO new!), and running decent at the track. Not easy to achieve, but let's see what happens with the TB. Brer the FAST intake you have, does it have the changable runner setup?
Old Sep 19, 2021 | 03:04 PM
  #74
BigDaddy97's Avatar
The different runner lengths sell separately. I would go straight to the short ones. https://www.summitracing.com/parts/fst-146071
Old Sep 19, 2021 | 04:07 PM
  #75
LS1Tech Co-Founder
From talking to you guys and few others I know, I think the suggestions are:
  • What valve springs, what installed height, maybe sure not valve float?
  • FAST shorter runners just a good general move
  • NW 103 TB, a good general moved, has been ordered
  • Depending on compression, consider running E85 or race gas
  • One long time friend wonders if there is a spark issue, I don't think there was but I'll add it here
If he wants to step it up:
  • More cam
  • CID intake + 4500 TB
  • 2" or more headers
Old Sep 19, 2021 | 04:39 PM
  #76
ddnspider's Avatar
Headers and a cam don't explain away that Dyno graph. It's throwing money at it instead of fixing the root cause.
Old Sep 19, 2021 | 05:55 PM
  #77
LS1Tech Co-Founder
BTR .660 springs btw
Old Sep 19, 2021 | 06:11 PM
  #78
Default fast runners
I have the long runners in now, I also have the next size shorter runners available to put in. the plan is to do the throttle body and log a few runs on the good old Edens expressway after some street driving. Then trying to hit the Dyno where I can swap runners and see what works best.
Old Sep 19, 2021 | 06:16 PM
  #79
BigDaddy97's Avatar
I've ran those runners in the past , you probably won't see a hp increase from them but they will shift your powerband 3 to 500 rpm north.
Old Sep 20, 2021 | 09:11 AM
  #80
psicko's Avatar
Chicago.
psicko, did you have a suggestion?
Is there any chance the throttle isn't opening 100%? I knew a guy that had an issue with swapping a DBW pedal and control module into an older car and it wasn't reading 100% opening. He gained like 50whp from getting that fixed lol.
