Greg Good TFS Ls 7 heads
As long as you can cut a good 60ft, it will. Going to need a real low 1.5, minimum. I ran a best of 10.2 @142.5 with a 1.66 60ft. Didn't go to the track much to practice with the 60ft.
The following users liked this post:
Corona (10-24-2021)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
So did Greg Good recommend those heads (TFS LS7) for your build or you wanted them? Looks like a great build.
I just did a google search and looks like Darrin Morgan joined BES racing in March, 2021.
No I have had them for a couple years.the reason I bought them they were the cheapest ls 7 heads out there @the time(aftermarket) that setup for a hydraulic or solid shaft system.(I bought them bare)I was having lifters trouble so I decided to have them milled (65”cc) and ported .Greg talk me into a bigger intake valve.i was running Ferrea hollow stem 2.200/1.615 valves on intake and exhaust.TEA drilled shaft bolts to 7/16 for the shaft system.
Corona (10-24-2021)
