LSX 454 and Boost
I have a LSX 454 that I bought used 3 years ago. I'll try to keep this as short as possible.
I rebuilt this thing twice already.
Setup is: 2008 C6 Z06 LSX 454, 4.200 Bore, 4.185 Stroke, Custom Spec Stage 2 LS7 Cam (Will change), RHS LS7 Pro Elite Cyl Heads 291CC, Comp Shaft Mount Rockers, ARH 1 7/8 Headers, FAST 102 (Will change to Mamo MSD), ID1050x Injectors.
My question is, can I boost this thing? Would you do it on a 4.200 bore which is the max bore size after which it will need resleeving on the next rebuild I'm guessing.
If so, would you procharge it at around 10psi or around a 200 shot of NOS? Why and why not?
This thing proved to be a money pit lol. But so far from the last build and tune it has all been going great so far. Fingers crossed.
Appreciate any input.
Having said that, a 4.2” iron based build is going to be much stronger than a 4.2” aluminum build. 10psi isn’t a lot of boost by today’s standards. The elephant in the room here, is what happens when you get bored with the 10psi and want to jump it up to 15-18psi? Oh yes you will!
Why so many rebuilds?
LSX will have provisions for 6 bolt cylinder heads. To answer your question though it's not recommended to exceed 4.125 bore or 4.000 inch stroke for power adders.
Below pic attached from last rebuild to give you an idea of the cylinder walls.
The guys at the shop here checked and it did seem like an LSX block they checked the casted part number apparently. Also, according to the original builders of this engine "Hardcore Racing Parts", it is an LSX 454, 4.185 Bore, 6.125 rods, 4.125 Stroke I'm not sure if this whole engine should be dumped or not at this point lol.
Here are some more pics in the hope of anyone being able to identify what block this really is lol. Thread moved from boost to wrong block real quick hahaha
I can guarantee you do not have an LSX (GM trademark) racing engine block. It also did not start life as a 454. It was probably born a 5.3 or 6.0 for a truck.It is fairly common for shops to take a 5.3 (because the block is cheap) and re-sleeve it with aftermarket cylinder sleeves, and then size the bore to what they want. So it could have been a 454 cubic inch engine, but probably based on a production truck block. It's kind of important to know what sleeves you have in that engine in order to decide how much power you can put to it.
MY BAD! I compiled images from a WhatsApp chat between me and the shop and failed to realize the dates as well as the differences in the pics! lol.
I guess the question still remain,
Would you boost a 4.200 LSX block? If so, by how much? Obviously will also be running Meth.
Or would you stay NA?
Thanks!
Thanks!
Cylinder wall thickness and Core shift @ 4.200
How much boost? IDK, but Reference the statement above. Detonation would be the main problem to worry about and the block being @ 4.200 not many rebuilds nor gasket Selection using Boost. Btw on the boost reference a 4.200 bore LSX gasket.
Look at the space between the cylinder's 😏
You can add boost but ....
