Thoughts?
Old Nov 10, 2021 | 07:40 AM
Surewhynot's Avatar
Default Thoughts?
Good morning everyone, Im building a 5.3 10:1 (lc9), 799 heads, Ls6 intake with a 4l60. Its going in a 1939 Chevy, about 3000lbs. Looking for thoughts on a cam with these specs 218/227 .523/.523 112+3? Trying to find a good cruising cam without a valve spring change. Thank you.
Old Nov 10, 2021 | 09:41 AM
PARMY's Avatar
Get the valve spring that matches the cam. In the end it will be worthwhile and springs for that cam would not be expensive. The last thing you want to run into is any sort of valve float issues, small cam or not.
Old Nov 10, 2021 | 10:21 AM
Check out Summit 8701R1 218/227, .522/.524,112+2. That is basically the Summit version of the GM Hot Cam with many refinements.
If you still have stock LC9 springs in there you will need to change springs. Stock springs can't handle anything over about .500.
Old Nov 10, 2021 | 08:43 PM
Surewhynot's Avatar
No stock lc9 springs, I have a set of Ls6/3 style springs
Old Nov 10, 2021 | 11:41 PM
They will be fine.
Old Nov 13, 2021 | 05:58 AM
99 Black Bird T/A's Avatar
If staying NA, I'd want more compression. At least 11.5 to 1 ideally 11.8 to 1. You can go as high as ~ 12.2 to 1 with 93
10 to 1 is pretty tame and leaves a lot on the table.
Old Nov 13, 2021 | 10:09 AM
Surewhynot's Avatar
Its just a sbe engine. I didnt feel a need to change pistons. Although, maybe Ill try and find a thinner head gasket. just to clarify the intent of the engine, Im building this for my 75 year old dad. He isnt looking for all of the horsepower, just building a cruiser. Looking for good manners, fuel economy, reliability and with a little more aggressive idle. Thank you
Old Nov 13, 2021 | 10:53 AM
Then leave the compression where it is. With the lower dynamic compression from the cam, you should even be able to use 87 regular gas. Keep it simpler for us older guys...
Old Nov 13, 2021 | 11:19 AM
RedXray's Avatar
The BTR "Truck Norris" camshaft would be a good choice.
Old Nov 14, 2021 | 02:03 PM
grinder11's Avatar
I TOTALLY AGREE on leaving the compression where it is. If OP insists on a bit more compression, maybe a 010" thinner head gasket. Sure, he could go a lot more rad, like some posts said, like 11.5-12.0:1. But you're close to the ragged edge on 93 octane when running a small cam, and Premium isn't getting any cheaper, or any higher in octane than 93, either. Also-Comp made, and may still make, a .560" lift, 224/224 on a 112 LSA, which would also be good. As Atsma said, don't change compression, or like I said, if you do, not much!!! Best of luck to you......
Old Nov 17, 2021 | 06:44 AM
Sounds like it should be a fun ride for your dad to cruise with and enjoy. A++
Old Nov 17, 2021 | 11:35 AM
gagliano7's Avatar
If you are keeping the stock torque converter the tried and true 5.3 cam 212/218 112 or 114.
https://www.texas-speed.com/p-5002-t...-camshaft.aspx
