Scat Rods Power Level
In theory an offshore lightweight rod has potential to be worse than stock. A few brands did not recommend their lightweight stuff be used for what I was intending for multiple reasons, even though a stock rod already survived it.
I frequent corvetteforums in the C4 sections because I technically own one. Some of the stuff I see there is absolutely absurd.
They have no problem spending $8-10k on a 425 hp 383 and absolutely refuse to believe an LS engine can make more than that without forged everything.
They argue about absolutely everything that seems derogatory to their cars in any way, refuse to believe the C4 isn't the best car in existence, and scoff at any logical comparison to another car you try to give them.
Some of those guys have their head so far up Nostalgia's a** that they refuse to believe anything that wasn't common knowledge in 1988.
If you want to make them cry, point out the C5Z06 will slaughter the C4ZR1
C3 crowd is very similar with many arguments that RamHorm manifolds are as good or better than 1 3/4 primary long tube headers.
The big end being more round has more to do with the life of the rod and not what it is made from or who made it. Put 250k miles on a set of forged rods and tell me they are still round.
Without metallurgy data, you can't directly argue that a lightweight forged rod with good fasteners is better.
If you had the metallurgy data, you wouldn't be so quick to make bold claims, either. Powered metal rods are technically "forged" in the same manner that aftermarket rods are.
Most powdered metal rods rank higher on the hardness scale than 4340 forged rods.
GKN, the driving force behind most current forged powdered metal technology even claims that powdered forgings are much stronger than typical forged steel.
https://www.gknpm.com/en/our-busines...als/forged-pm/
Most newer PM rods are made of ASTM 4260, which has both a higher yield strength and ultimate tensile strength than 4340.
Knowing that, you can't honestly say that 4340 rods forged in china are definitely free of forging imperfections and are 100% the material they are supposed to be.
they follow the metal all the way from the initial recycle through the process, foundering forging till they put them on the boat.
They had some issues back when they were forced to move the billet/forging processes offshore..
They learned their lesson and now NOTHING gets without supervision by their people.
The early Ford V10's that would lose the bore in 60K are another example..
You'd think American business would notice, but even today I see manufacturers getting burned by quality control in the offshore countries, they keep
making the mistake that they can just send a design and don't have to be exactly detailed in specs...
Covid has not helped a bit either..
Speaking of kids, even the gen4 engine my kid assembled didn't blow up. Careful, those heavy rods could fly out at any time!!
FWIW, I’ve seen the Scat I Beams hold up to 900whp. Out of the box, I think the pin bores are tight for any serious performance engine, but that’s a cheap fix that should be checked on any build anyways. I think they’re a great option to help take weight out of the rotating assembly and open up options for pistons.
Basically, boost reduces the stress on the rod bolts during the most crucial moments.
I also have an SBE LS2 that's been boosted since 2007, after 12 years of turbo abuse its finally nipped one ring land in 2019 seeing almost 30 PSI and didnt even damage the cylinder. I get people have bad luck sometimes, but the Gen 4 SBE stuff really seems incredibly strong for the average person. As mentioned before using aftermarket parts for under 1000hp is often more trouble than its worth.
Cesar routinely posts high hp SBE builds as well. He also says it's not worth corrupting a SBE with aftermarket parts for less than 1000hp.
I also have an SBE LS2 that's been boosted since 2007, after 12 years of turbo abuse its finally nipped one ring land in 2019 seeing almost 30 PSI and didnt even damage the cylinder. I get people have bad luck sometimes, but the Gen 4 SBE stuff really seems incredibly strong for the average person. As mentioned before using aftermarket parts for under 1000hp is often more trouble than its worth.I don’t think either is objectively better, you can use whichever you like. The Gen IV rod is robust and cheaper since they’re 20 years old and mass produced, but the Scats are light, have good ARP bolts, and open up a lot of options for piston choices.
