Scat Rods Power Level
This isn't a budget build or anything, but I don't want components that are made to support 1200 or 1500 hp. The plan with this build is to use forced induction and if I were looking at a lower power level the turbo wouldn't be necessary.
Thanks.
If I were to spend money on rods I wouldn't buy SCAT, but that's just me. I've also never been concerned with rod weight as it really doesn't matter on these engines under 8500RPM, above that I would go with an aluminum rod but even they are often over 600g.
Scats a nice rod. My engine builder even liked them, and he don’t like much.
That being said.... his rods are the 6.100" length, I've never searched for forged pistons for anything but 6.125" rods. But I don't think the selection's near as good for those 6.100"s.
I can't imagine that any forged aftermarket rod that weighs less and has better fasteners is going to be worse than the OEM rods.
A rating isn't a limit. Parts are typically given ratings that are within the range of what will prevent them from eventually suffering failure from fatigue life.
A rod rated to 700 HP should be able to handle 700 HP indefinitely under ideal circumstances. That doesn't mean it can't handle twice that.
In theory an offshore lightweight rod has potential to be worse than stock. A few brands did not recommend their lightweight stuff be used for what I was intending for multiple reasons, even though a stock rod already survived it.
I frequent corvetteforums in the C4 sections because I technically own one. Some of the stuff I see there is absolutely absurd.
They have no problem spending $8-10k on a 425 hp 383 and absolutely refuse to believe an LS engine can make more than that without forged everything.
They argue about absolutely everything that seems derogatory to their cars in any way, refuse to believe the C4 isn't the best car in existence, and scoff at any logical comparison to another car you try to give them.
Some of those guys have their head so far up Nostalgia's a** that they refuse to believe anything that wasn't common knowledge in 1988.
