replace valve springs or send it ?
The higher pressure the spring the more likely it is to happen.
On some sprints the springs are trashed about every 20 races..
Nobody I know road racing a top shelf motor stores their engines with the rockers on.
I've measured springs that have been in storage and found 50+ lb differences between the ones that were tight and the ones that were loose. Also can often measure significant differences in unloaded spring height..
Attention to Details for the win...
Poking fun at somenone who had an engine grenade on them isn't funny and it's certtainly not who I am. As for the valve springs there hasn't been any heat cycles ran through them and they're likely okay but I still recommend checking them. Otherwise it will be in the back of your mind as to how long before I really do need to change them and from what I've gathered so far the engine is on an engine stand.
Finding replacement springs for my Automag and Coonan won't be easy.
Basically in order to deform a spring, you have to compress it past its elastic limit, but the thing about spring steel is that its elastic limit is not a strongly defined value, and the tension on every part of the spring wire is not even, with it being much higher on the outer surface than inside the spring core. And if you have a high-lift cam, you need high lift valve springs that have few coils per inch. This means the torsion on each little part of the spring steel is higher than stock or lower lift springs, so in use it can be more likely to lose tension.
Also, valve springs, whether stored under compression or run in heavily used engines, will 'relax' and are expected to lose something like 10% of their tension, and a small amount of spring height, and then maintain that final 'relaxed' tension more or less indefinitely. The same phenomenon happens to suspension springs, leaf springs, all sorts.
Basically, from what I know about this, if you took your valve springs and compressed them all .600" and then stored them at that compression, or installed them in an engine with a .600 lift cam and drove them 100,000 miles, you will have your springs creep and relax somewhat. Its kind of unavoidable.
A potential issue is that in the stored engine the spring relaxation can be uneven, but if you run the springs they will even out eventually.
Please swap them if they are even slightly rusty, or they will crack.
By checking them..
