replace valve springs or send it ?
Quick question I built this motor 5 years ago set it into the car and then Life .
Do I need to change the valve springs after sitting for 5 year ? Motor was built and has never turned over . I think I should but want other opinions .
If it has solid roller lifters I'd definitely change the valve springs. Hydraulic roller lifters, the springs are probably OK.
However, valve springs aren't that expensive so for peace of mind it may be worth changing them.
You want to take chances then have at it and when you float a valve or worse drop one I'll be the first to say I told you.
No I am with you I can do them for about $200 myself
cheap insurance
......Poking fun at somenone who had an engine grenade on them isn't funny and it's certtainly not who I am. As for the valve springs there hasn't been any heat cycles ran through them and they're likely okay but I still recommend checking them. Otherwise it will be in the back of your mind as to how long before I really do need to change them and from what I've gathered so far the engine is on an engine stand.
