Big mother thumpa cam
I'd rather have a smooth cam, AKA Stealth Mode, and blow their doors off that way.
I know, it makes no real sense except for the scores of guys who think they're real cool. The Big ***** Thumper is for those guys.
It's your "daily", but do you use it as a truck? If so, you'd probably want some "truck" cam, and maybe keep a little more margin on the compression ratio. If you like to hot rod it around a bit and don't tow/haul as much, you could go a bit wilder on the cam and compression.
