Any downside to high pressure oil pump.
Ly6 build, Cletus bald eagle cam, long tubes, intake. Goal off 500hp crank +/- and keeping rpm limit at 6500. Street car that won’t see track time but will get driven with gusto quite a bit. I was originally going with a new gm oil pump but have since added a remote oil filter and accusump to the plan increasing oil volume in the system. Possibly an oil cooler in the future.Two questions:
My thoughts are that the flow demands of the oil system will be the same without increasing rpm, but with more oil to move, maintaining pressure might be more of a challenge. In my circumstances I’m assuming a high pressure pump like the melling 10295 would be a better choice than the high volume option. Expert opinions on that?
Second question. Assuming the pump is shimmed properly, is there a downside to running a high pressure pump if it’s not necessary? Is this something where overkill could be detrimental or is it just an extra $60 spent it’s something I don’t really need. Id rather overbuild and be safe than find out the hard way my pressure is inadequate.
thanks for your time
A high pressure pump's only difference is the higher cracking pressure of the relief valve.
A remote filter and/or Accusump does not change any volume demands on the oil system. Nor do they bleed off pressure. Even a stock-spec pump would be fine in your situation.
It's highly unlikely that the addition of the remote oil filter setup and potential oil cooler will have any noticeable effect on oil flow or pressure with an OEM pump. Even if pressure does fall a few psi, it doesn't matter. The OEM pump is already multiple times more than what the engine actually needs.
High pressure pumps are a solution looking for a problem.
