NA 416 High Compression Build - 2011 Camaro
#81
#83
Final numbers on E85 were 642/477. Little lower than I thought on both sides but still pretty solid for E85 on a 416. It has some more in it with little here-and-there things coming in the future. Picking it up tomorrow and super excited!
#86
Well, I think we are all not surprised by the power it made, but the torque is definitely lower than expected by a good 50 wheel
The following users liked this post:
02EBC5Z06 (01-26-2023)
#89
As long as it runs good, yolo
logan2ss (06-12-2023)
#94
I am getting ready to try out some 1/8mi testing to see how it does in the heat. Only data I have so far is a 60-130 pull during 2k. Pump E85, extra 100-150 lbs, starting in 3rd gear it did a 6.01. Better fuel and weight out and maybe starting at around 40-50mph it should be able to pick up. DA was low then so if I matched that time in the summer that would be great.
02EBC5Z06 (06-12-2023)
#96
Gotcha.. Just trying to gauge what kind of timing the new motor for mine is going to want. It's around 14.3:1, but I figured around 21-24 is where it would end up. Seems like it possibly might take a bit more, but we'll see!
#98
While it is on my mind to post here, I might as well. Trying to see when the next Test and Tune events are at the 1/4 nearest to me. Have not gotten the 2 step or line lock wired in yet, life getting in the way. Still would like to take it to the track and get a PB run and see what mph range I will be in for the trap speed. Will try to update as I find out anything new.
02EBC5Z06 (10-02-2023)
#100
